Curve.Extend
Curve.Extend
Message 1 of 16
Curve.Extend
Hey guys, I am programming in C# and I am trying to extend the end point of a curve to another line and am having some trouble.
Could you by chance explain the Curve.Extend function to me, as well as what the syntax (bool extendStart, Point3d toPoint) means, and/or give an extend alternative if you have any.
Accepted solutions (3)
Replies (15)
Message 2 of 16
Alexander.Rivilis
Sample code:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
#pragma warning disable 0618
[assembly: CommandClass(typeof(ExtendLine.MyCommands))]
namespace ExtendLine
  public class MyCommands
    [CommandMethod("ExtendLine")]
    public void MyCommand()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      if (doc == null) return;
      Editor ed = doc.Editor;
      PromptEntityResult rs1 = ed.GetEntity("\nSelect curve for extend operation: ");
      if (rs1.Status != PromptStatus.OK) return;
      if (!rs1.ObjectId.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(Curve)))) {
        ed.WriteMessage("\nIt is not a Curve");
        return;
      PromptEntityResult rs2 = ed.GetEntity("\nSelect boundary curve: ");
      if (rs2.Status != PromptStatus.OK) return;
      if (!rs2.ObjectId.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(Curve)))) {
        return;
      using (Curve cv1 = rs1.ObjectId.Open(OpenMode.ForWrite) as Curve)
      using (Curve cv2 = rs2.ObjectId.Open(OpenMode.ForRead) as Curve) {
        Point3dCollection pts = new Point3dCollection();
        cv1.IntersectWith(cv2, Intersect.ExtendThis, pts, IntPtr.Zero, IntPtr.Zero);
        if (pts.Count > 0) {
          Point3d p = pts[0];
          Point3d pStart = cv1.StartPoint;
          Point3d pEnd = cv1.EndPoint;
          bool bStart = (p.DistanceTo(pStart) < p.DistanceTo(pEnd));
          try {
            cv1.Extend(bStart, p);
          catch (Autodesk.AutoCAD.Runtime.Exception ex) {
            ed.WriteMessage(ex.ToString());
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 16
So, I was able to make this work with my predetermined curves, but is there any way to extend it to the point at which the line WOULD intersect if cv2 kept going, but doesn't due to the line being too short to reach?
Example Image:
Message 4 of 16
Alexander.Rivilis
Try to replace this line of code:
with this line:
cv1.IntersectWith(cv2, Intersect.ExtendBoth, pts, IntPtr.Zero, IntPtr.Zero);
Expert Elite Member
Message 5 of 16
If I could give you like ten Kudos per post, I would! Thanks a bunch!
Message 6 of 16
So another question; how would I extend a line to the intersecting point, and then an additional 10 feet in the same direction?
Message 7 of 16
Whoops, that last comment above was meant to be in reply to you.
Message 8 of 16
Alexander.Rivilis
You have to use this algorithm to calculate point for extend: http://forums.autodesk.com/t5/net/how-to-get-point3d-between-two-point3d/m-p/6587893#M50386
Expert Elite Member
Message 9 of 16
In this case, would you modify the Point3dCollection to contact set values from that equation?
Message 10 of 16
Alexander.Rivilis
It is easy for me post a code:
using System;
    [CommandMethod("ExtendLineWithOffset")]
    public void ExtendLineWithOffset()
        ed.GetEntity("\nSelect curve to extend: ");
        ed.WriteMessage("\nIt is not a curve!");
        return;
        ed.GetEntity("\nSelect boundary: ");
        return;
      PromptDoubleResult rsOff = ed.GetDistance("\nOffset <0>: ");
      double offset = (rsOff.Status == PromptStatus.OK) ? rsOff.Value : 0;
        if (pts.Count > 0)
          Point3d p = pts[0];
          double dist = Math.Min(p.DistanceTo(pStart), p.DistanceTo(pEnd));
          for (int i = 1; i < pts.Count; i++)
            if (pts[i].DistanceTo(pStart) < dist)
              p = pts[i]; bStart = true;
              dist = p.DistanceTo(pStart);
            else if (pts[i].DistanceTo(pEnd) < dist)
              p = pts[i]; bStart = false;
              dist = p.DistanceTo(pEnd);
          try
            Vector3d dir = (p - ((bStart) ? cv1.StartPoint : cv1.EndPoint)).GetNormal();
            p += dir * offset;
Expert Elite Member
Message 11 of 16
So I am running into an issue with the code, once I alter it to extend PAST the point, it refuses to extend that side at all.
                                    Curve ptLiveEnd = resCV3.ObjectId.Open(OpenMode.ForRead) as Curve;
                                    Point3dCollection ptss = new Point3dCollection();
                                    subCurv.IntersectWith(ptLiveEnd, Intersect.ExtendBoth, ptss, IntPtr.Zero, IntPtr.Zero);
                                    if (ptss.Count > 0)
                                        Point3d p2 = ptss[0];
                                        Point3d pStart2 = subCurv.StartPoint;
                                        Point3d pEnd2 = ptLiveEnd.EndPoint;
                                        bool bStart2 = (p2.DistanceTo(pStart2) < p2.DistanceTo(pEnd2));
                                        double dist = Math.Min(p2.DistanceTo(pStart2), p2.DistanceTo(pEnd2));
                                        double offst = 24;
                                        for (int i = 1; i < ptss.Count; i++)
                                            if (ptss[i].DistanceTo(pStart2) < dist)
                                                p2 = ptss[i];
                                                bStart2 = true;
                                                dist = p2.DistanceTo(pStart2);
                                            else if (ptss[i].DistanceTo(pEnd2) < dist)
                                                p2 = ptss[i];
                                                bStart2 = false;
                                                dist = p2.DistanceTo(pEnd2);
                                        try
                                            Vector3d dir = (p2 - ((bStart2) ? subCurv.StartPoint : subCurv.EndPoint)).GetNormal();
                                            p2 += dir*offst;
                                            subCurv.Extend(bStart2, p2);
                                        catch (Autodesk.AutoCAD.Runtime.Exception exx)
                                            acEd.WriteMessage(exx.ToString());
Message 12 of 16
Alexander.Rivilis
I think it's time you learn how to use a debugger to see what wrong with your's code.
Look like you can not rewrite my code. Why you use:
Maybe you have to use:
Point3d pEnd2 = subCurv.EndPoint;
Expert Elite Member
Message 13 of 16
Ah; ptLiveEnd is cv2, and subCurv is cv1 essentially, they aren't chosen, but pre-determined by earlier parts of the code.;
Message 14 of 16
Alexander.Rivilis
Compare with my code.
Expert Elite Member
Message 15 of 16
You sir, are very patient and helpful.
I am, however, an idiot.
That fixed it xD
Message 16 of 16
One last problem that I am running into. It works perfectly in all cases except for if the line to extend to is already the end point. How would I have it extend two feet past the line of extend even if it is already at that line.
