Current Drawing Location Path
Hi Guys,
I am using vb.net and I need to find the directory path that my current or open drawing is located in.  I'm not sure how to get this from vb.net.  Any help is appreciated.   Thanks.
Take a look at
Document.Name
Database.OriginalFileName
        <CommandMethod("GetFileName")> _
        Sub GetFileName()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            ed.WriteMessage(doc.Name & vbCrLf)
            ed.WriteMessage(db.OriginalFileName)
        End Sub
Sorry you want the folder,
 Application.GetSystemVariable("DWGPREFIX")
or another way
make sure you Import System.IO
Change previos Post to
        Sub GetFileName()
            ed.WriteMessage(Path.GetDirectoryName(doc.Name) & vbCrLf)
            ed.WriteMessage(Path.GetDirectoryName(db.OriginalFileName))
        End Sub
Thank you for your post.  This is exactly what i was looking for.  I have a another question now that I'm seeing the output of this.  Is there a way to go up one folder level in the directory path?  Or i would have to manually trim the string?
        Sub GetFileName()
            ed.WriteMessage(Path.GetDirectoryName(db.OriginalFileName) & vbCrLf)
            Dim fpath As String = Path.GetDirectoryName(doc.Name)
            While fpath <> Nothing
                ed.WriteMessage(fpath & vbCrLf)
                fpath = Path.GetDirectoryName(fpath)
            End While
            fpath = doc.Name
            Dim levels As Integer = ed.GetInteger("Enter number of levels you want" & vbCrLf).Value
            For i As Integer = 0 To levels
                If fpath = Nothing Then
                    Exit For
            Next
        End Sub
