CUI managed API - standalone .net application - add image to RibbonCommandButton
I'm creating standalone .net application, where I opening .cuix file, creating new ribbon panel, and adding elements.
So far so good.
Last elements I have to add are several RibbonCommandButton, which should be very simple: have image, text, and execute command. All that I can do, but cannot assign image to button.
I followed instructions from documentation, and answers on similar questions here on forum, I attempting to add image to macro, by using syntax:
MacroGroup macGroup = cs.MenuGroup.MacroGroups[0];
MenuMacro menuMacro = macGroup.CreateMenuMacro("SomeMacroName", "SomeCommand", "SomeTag", "SomeHelp", MacroType.Any, "[full path to image.png]", "[full path to image.png]", "SomeLabel");However, here I get null reference exception.
Full stack trace is:
at Autodesk.AutoCAD.Customization.CustWrap.addLooseImage(String imgSrcPathName, CustomizationSection resolver)
at Autodesk.AutoCAD.Customization.Macro..ctor(String name, String command, String helpStr, MacroType mType, String smlImage, String lgImage, String labelID, MenuMacro par)
at Autodesk.AutoCAD.Customization.MacroGroup.CreateMenuMacro(String name, String command, String tag, String help, MacroType macroType, String smallImage, String largeImage, String labelId)I suspect that something is wrong with parameter for image. In examples I found on forum, it is only set file name for image (without path), like "image1.png". I attempted that (put image1.png into same folder where acad.exe is, however, no success).
Then, I attempted to put here full (absolute) path to image1.png on disk, but again, the same error.
Can you, please, tell me what am I doing wrong?
Thanks.
