Announcements
Creating PalleteSet Makes Autocad slow
m_maneesh2000
m_maneesh2000
I'm having multiple WPF forms which are displayed one after another.
To display the WPF UI's in autocad I'm creating a new PaletteSet and using ElementHost to render the WPF Forms. Below is the sample code
DynamicWPFAllFormsCtrl.Instance.CloseAllForms();
//DisplayItems.DisplayItemsList.Instance.closeUI();
// Create the palette setSiz
PaletteSet _ps = new PaletteSet(heading);
_ps.DockEnabled =
(DockSides)((int)DockSides.Left + (int)DockSides.Right);
_ps.MinimumSize = new System.Drawing.Size(550, 360);
// Dock the palette to the left
// Create our first user control instance and
// host it on a palette using AddVisual()
ElementHost host = new ElementHost();
host.AutoSize = false;
host.Dock = DockStyle.Left;
host.Child = this;
_ps.Add("", host);
// Display our palette set
_ps.KeepFocus = true;
_ps.Visible = true;
_ps.Dock = DockSides.Left;
_ps.RolledUp = false;
DynamicWPFAllFormsCtrl.Instance.AddForm(_ps);
Inside CloseForms() function I'm just closing the paletteSet like PaletteSet.Close().
After creation of few PaletteSets the autocad is taking time to render the forms. I'm getting some white screen before rendering the next form. Should we call any functions to close the palette along with close()? Seems like close() function is not clearing the memory entirely.
norman.yuan
Firstly, this forum is for AutoCAD VBA/COM API. PaletteSet is a class in AutoCAD .NET API, thus you should have posted in .NET API forum here.
You only showed your code of creating the instance of a PaletteSet, which by itself has nothing to do with the issue of slowness. It looks like the issue is with what the class DyamicsWPFAllForms. So you should show its code (and all possible classes that related to it).
Are you creating multiple PaletteSets and adding them to that class? If so, it is wrong: PaletteSet is meant to be used as singleton object: once it is created, it cannot be removed from the memory until AutoCAD session ends. Its Close() method is simply set it to invisible.
Again, not seeing the relevant code, I cannot comment more.
Also, there is no need to use ElementHost for adding WPF Usercontrol as Palette. It is only used for very earlier versions of AutoCAD .NET API (prior to Acad2007/2008?). You can use AddVisual() to directly add WFP UserControl as Palette.
Norman Yuan
Drive CAD With Code
m_maneesh2000
Hi @norman.yuan,
Thanks for your response. As suggested, using a single palette for all UIs has significantly improved performance.
However, I’m facing another issue. My UIs have different widths, and these widths are set correctly when the palette is docked. But if the palette is auto-hidden at least once, the widths are no longer applied properly when the palette is auto-hidden.
To address this, I wrote the following code, but this is causing a big struck/glitch when opening the palette. Is there any other way to resolve this?
And it seems like to Dock, I need to make the palette visible. To keep AutoRollUp as false, dock should be set as None. So, enabling the paletteset has become mandatory to apply those changes.
        public void AddFormToLeftPalette()
            try
                //CloseItemsInsideLeftPaletteSet();
                if (leftPaletteSet == null)
                    leftPaletteSet = new PaletteSet("");
                    leftPaletteSet.DockEnabled =
                    //_rightPaletteSet.Style = PaletteSetStyles.ShowCloseButton;
                leftPaletteSet.Visible = false;
                leftPaletteSet.Name = heading;
                Palette palette = leftPaletteSet.AddVisual(heading, form);
                leftPaletteElements.Add(palette, onCloseCallback);
                //_leftPaletteSet.KeepFocus = true;
                leftPaletteSet.Visible = true;
                leftPaletteSet.Dock = DockSides.None;
                leftPaletteSet.AutoRollUp = false;
                leftPaletteSet.Size = new System.Drawing.Size(width, height);
                leftPaletteSet.Dock = DockSides.Left;
                leftPaletteSet.RolledUp = false;
                if (isStateChangedHandlerSubscribedForLeftPalatteSet)
                    leftPaletteSet.StateChanged -= LeftPaletteSet_StateChanged;
                leftPaletteSet.StateChanged += LeftPaletteSet_StateChanged;
                isStateChangedHandlerSubscribedForLeftPalatteSet = true;
            catch (Exception ex)
                AcadDocumentEditorCtrl.LogException(ex);
norman.yuan
Not sure I understand what exactly the issue is, but it sounds like you want the PaletteSet to have certain size (width and/or height) when the PaletteSet being docked/undocked, or autohidden/unhidden. From my experience, it is very difficult to know exactly PaletteSet's size. Rather, we could focus on making the Palette content auto-resizeable. That is, use scrollable UserControl as the Palette, which is pretty easy with WPF.
Norman Yuan
Drive CAD With Code
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
