Could an object be equal to null ?
J-Rocks
Message 1 of 11
J-Rocks
I have seen in many programs programmers checking out if an object is not equal to null then proceed to next line .
Is it possible for example in the below codes the object be equal to null ? if not , why programmers using this check out then ?
thanks in advance.
if (per.Status == PromptStatus.OK)
                using (Transaction MyTrans = db.TransactionManager.StartTransaction())
                    try
                        BlockReference Myblk = (BlockReference)MyTrans.GetObject(per.ObjectId, OpenMode.ForRead);
                        if (Myblk != null)
Accepted solutions (4)
Replies (10)
Message 2 of 11
SENL1362
You're example may not result in a NULL value and if the ID is not a BlockReference it may even throw an exception, but this one sure can:
Circle cr=tr.getobject(someId, OpenMode.ForRead) as Circle;
The ID may not be valid, such as marked for Delete or Disposed or not yet Comitted etc. and that also may result in a NULL value fot the BlockReference. You never know so testing may be essential.
The above prevents the Throw which is an expensive action -- in time context, when the someId not belong to a Circle but to a different object.
This construction is often used as an alternative to a Switch statement when there are limited choices.
In general testing for null is good practice and relatively cheap so use it as much as possible, especially when a property of the object will be used, such as in,  cr.Center, you are in big trouble when cr IS NULL.
In the next version of C this is a short cut to prevent these situations: cr?.Center
See also nullable types: bool? flag=null;
The alternative for a Switch when limited choices:
for instance in the next sample w're only interested in a circle
foreach(ObjectId in someBlockTableRecord)
    if (cr != null)
         //process circle
Message 3 of 11
J-Rocks
Thank you .
it is a little bit confusing to me to get it right , sorry.
Assume that I asked the user to select objects then the program would run on the same quantity of the selection sets then how could objects in the selection set would be in a way or another be equal to null ? this is entirely unreasonable to me at least.
Message 4 of 11
FRFR1426
In your case, the variable Myblk can not be null. If the Id is not valid GetObject will throw an exception. And the cast to BlockReference will also throw an exception if it fails, so the null check should be removed to improve readability
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 5 of 11
J-Rocks
Thank you.
My first example was just to descibe my idea .
Should I check if the line entity is not equal to NULL in this example ?  and why ?
TypedValue[] tv = new TypedValue [] { new TypedValue(0, "LINE") };
                SelectionFilter fltr = new SelectionFilter(tv);
                PromptSelectionResult ss = edit.GetSelection(fltr);
                if (ss.Status == PromptStatus.OK)
                  foreach (SelectedObject obj in ss.Value)
                            Line ent = trans.GetObject(obj.ObjectId, OpenMode.ForRead) as Line;
                      if (ent == null)
Message 6 of 11
SENL1362
not required
Message 7 of 11
FRFR1426
In this case, yes because you're using a soft cast (keyword as). A soft cast returns null if the cast fails whereas an hard cast throw an exception. In this specific case, I will use an hard cast because the entity type can only be a line (selection set filters on entity type LINE).
TypedValue[] tv = new TypedValue [] { new TypedValue((int)DxfCode.Start, "LINE") };
    Line ent = (Line)trans.GetObject(obj.ObjectId, OpenMode.ForRead);
Maxence DELANNOY
Manager
http://wiip.fr
Message 8 of 11
jeff
It's not you have a empty object, its the variable does not point to a object.
As FRFR1426 pointed out If your looking at examples where the as operator is being used to check an object's type then checking the result for null is needed to verify it.
GetObject() -> returns type Entity.
So this might be a a workflow seen getting lines from model space
            foreach (var obj in ModelSpace)
                  if (ent == null)
Here what i do using library from here and mentioned here
                var modelSpace = Db.ModelSpace();
                foreach (var line in modelSpace.GetEntities<Line>())
                    //////do what needed
You can also find your answers @ TheSwamp
Message 9 of 11
J-Rocks
THANK YOU ALL.
Can I come up with a believe that says :
If I get the object with (CAST) builder and the object comes from a selection set with a filter with a specific entity names < say lines > or by a PromptEntityResult wouldn't needed using to get sure if that object is not equal to NULL ?
And if iterating through objects in blocks , Model , Layout spaces I need to check the object out since the object might not be as per the object type that I am searching for ( for instance <Line> ) and the object might be a Circle , Text ... etc and not the type one that I want to get ?
Message 10 of 11
_gile
Yes.
To go a little further, when iterating a collection of ObjectIdS (e.g. a BlockTableRecord), you can, as said upper, open the objects with the as 'try cast' operator and check if the object is non null:
foreach (ObjectId id in modelSpace)
    Line line = tr.GetObject(id, OpenMode.ForRead) as Line;
    if (line != null)
But since AutoCAD 2009, if I remember correctly, you can determine the object type of an ObjectId without opening it (with the ObjectClass property) and, then, use the 'direct cast' operator, which is much more efficient.
    if (id.ObjectClass == RXObject.GetClass(typeof(Line)))
        Line line = (Line)tr.GetObject(id, OpenMode.ForRead);
Gilles Chanteau
GileCAD
GitHub
Message 11 of 11
J-Rocks
Thanks gile for your explanations.
