Coordinates Table to Text File C#
k005
Advisor Advisor
k005
Hello
How can I save the coordinate list to a text file?
Thanks.
fsztuczny
Add reference to the System.Windows.Forms
    [CommandMethod( "tableToTextFile", CommandFlags.Modal )]
    public void tableToTextFile() // This method can have any name
      // Put your command code here
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Database db = doc.Database;
      try
        PromptEntityOptions peo = new PromptEntityOptions( "\nPick a table: " );
        peo.SetRejectMessage( "\nThis is not a table!" );
        peo.AddAllowedClass( typeof( Table ), true );
        PromptEntityResult per = ed.GetEntity( peo );
        if( per.Status != PromptStatus.OK )
          return;
        ObjectId tableId = per.ObjectId;
        string filePath = null;
        using( System.Windows.Forms.SaveFileDialog saveDialog = new System.Windows.Forms.SaveFileDialog() )
          saveDialog.Title = "Save the text file as...";
          saveDialog.DefaultExt = "*.txt";
          saveDialog.Filter = "Text files|" + saveDialog.DefaultExt;
          saveDialog.AddExtension = true;
          saveDialog.CheckFileExists = false;
          saveDialog.CheckPathExists = true;
          saveDialog.OverwritePrompt = true;
          saveDialog.FilterIndex = 0;
          saveDialog.InitialDirectory = Environment.GetFolderPath( Environment.SpecialFolder.MyDocuments );
          System.Windows.Forms.DialogResult dr = saveDialog.ShowDialog();
          if( dr != System.Windows.Forms.DialogResult.OK )
            return;
          filePath = saveDialog.FileName;
        } //using( System.Windows.Forms.SaveFileDialog openDialog = new System.Windows.Forms.SaveFileDialog() )
        using( System.IO.StreamWriter sw = new System.IO.StreamWriter( filePath ) )
          const string fileColumnSeparator = "\t" /*tabulator*/;
          using( Transaction tr = db.TransactionManager.StartOpenCloseTransaction() )
            Table tab = tr.GetObject( tableId, OpenMode.ForRead ) as Table;
            for( int r = 0; r < tab.Rows.Count; r++ )
              System.Text.StringBuilder sb = new System.Text.StringBuilder();
              for( int c = 0; c < tab.Columns.Count; c++ )
                sb.Append( tab.Cells[r, c].TextString );
                if( c < tab.Columns.Count - 1 )
                  sb.Append( fileColumnSeparator );
              sw.WriteLine( sb.ToString() );
      catch( System.Exception e )
        ed.WriteMessage( e.ToString() );
You can also using built-in command: "_TABLEEXPORT"
k005
@fsztuczny
The codes are working properly. saved the txt file.
Can I print only "Num. of .vert" "X", "Y" values without a table?
so the table is exploded
fsztuczny
Sure. You can change the loop:
            for( int r = 1; r < tab.Rows.Count; r++ )
k005
@fsztuczny
In that :
in some cases there is a table.
in some cases there is also DBTEXT.
fsztuczny
Unfortunately, this is related to the multi-level sorting of the text insertion coordinates and taking into account the text dimensions. This is not to be done in a moment. May introduce potential errors in the order of the texts. Stay with the table.
Maybe someone else will find a simple solution.
k005
@fsztuczny
Thank you so much. For your help
