Our Current system:
A desktop windows application. The Autocad commands are implemented in c#. Netload is used to load the commands to make them available to Autocad
A simple use case to understand our system’s Autocad interaction scope: Users import a drawing file. They interact with the Autocad and mark a boundary. Inside the boundary they place objects. We run the Commands(from c# lib) and generate the final drawing representation on the Autocad
We have a roadmap to migrate our desktop application to a web application. So, I am trying to understand how the web portion of Autocad will need to be designed. I have gone through the below materials regarding the Autocad web integration.
- https://www.autodesk.com/products/autocad-web-app/overview?plc=ACDIST&term=1-YEAR&support=ADVANCED&q...
- https://knowledge.autodesk.com/support/autocad-web-app/learn-explore/caas/CloudHelp/cloudhelp/ENU/Au...
- https://www.autodesk.com/autodesk-university/class/Connect-AutoCAD-Web-HTML5-and-JavaScript-2014
- https://www.keanw.com/2015/11/au-2015-handout-integrating-net-code-with-autocad-io-to-add-design-int...
- https://www.keanw.com/2012/04/exposing-a-restful-web-service-for-use-inside-autocad-using-the-aspnet...
- https://www.autodesk.com/autodesk-university/class/Integrating-NET-Code-AutoCAD-IO-Add-Design-Intell...
Here is what I have in mind. Is my understanding correct?
Here are few questions
- To replace the AutoCAD Desktop App with the AutoCAD Web App - Does AutoCAD web app provide a single sign on feature?
- Convert the existing C# lib commands to core modules that can be packaged to AutoCAD I/O as an activity
- Does AutoCAD Web integrate with AutoCAD I/O?
- Instead of going for AutoCAD Web or AutoCAD I/O, is it possible to host these services inhouse?
Please let me know if there are other reference links that can be of help related to this.
