.NET
Connect AutoCAD to database using Entity Framework Core (.Net 8.0)
2 REPLIES 2
mdoyon1
178 Views, 2 Replies
I have been spending the past couple of days to connect a database to AutoCAD in order to store attribute data. I used EF6 for AutoCAD 2023 (.Net Framework 4.8) but it gets more complicated with the migration to .Net Core.
The error happens when creating a ApplicationDbContext and some file dll cannot be loaded.
Error message when trying to create a database context:
System.IO.FileLoadException: 'Could not load file or assembly 'Microsoft.Extensions.DependencyInjection.Abstractions, Version=9.0.0.0,
There are only two files in the project for now:
Class1.cs:
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
using Microsoft.EntityFrameworkCore;
using Microsoft.Extensions.DependencyInjection;
using Application = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: ExtensionApplication(typeof(DatabaseAutoCAD.ExtensionApplication))]
[assembly: CommandClass(typeof(DatabaseAutoCAD.Class1))]
namespace DatabaseAutoCAD
    public class ExtensionApplication : IExtensionApplication
        public void Initialize()
        public void Terminate()
    public class Class1
        [CommandMethod("CreateProduct")]
        public void CreateProduct()
            using (var db = new ApplicationDbContext())
                db.Database.EnsureCreated();
                var product = new Product
                    Name = "Product 1",
                    Description = "Description 1"
                db.Products.Add(product);
                db.SaveChanges();
entities.cs
using System;
using System.Collections.Generic;
using System.ComponentModel.DataAnnotations.Schema;
using System.ComponentModel.DataAnnotations;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
    public class Product
        [Key] // Primary Key
        public int Id { get; set; }
        public string Name { get; set; } = string.Empty;
        public string? Description { get; set; } // Optional property
    public class ApplicationDbContext : DbContext
        public DbSet<Product> Products { get; set; } = null!;
        public ApplicationDbContext(DbContextOptions<ApplicationDbContext> options) : base(options)
        public ApplicationDbContext() : base()
        protected override void OnConfiguring(DbContextOptionsBuilder optionsBuilder)
            optionsBuilder.UseSqlite("Data Source=app.db"); // Replace with your connection string
        protected override void OnModelCreating(ModelBuilder modelBuilder)
            base.OnModelCreating(modelBuilder);
            // Fluent API configurations (optional)
            modelBuilder.Entity<Product>()
                .HasIndex(p => p.Name)
                .IsUnique(); // Ensure the product name is unique
I added the following statement in the project settings in order to copy the file assemblies to the output directory:
<CopyLocalLockFileAssemblies>True</CopyLocalLockFileAssemblies>
The dll is now present in the folder when the build is completed.
Any help would be very much appreciated! Thanks
Labels (2)
2 REPLIES 2
norman.yuan
in reply to: mdoyon1
Since Acad2025 uses .NET 8, you need also upgrade the Entity Framework from 6.x to Miscrosoft.EntityFrameworkCore. It looks to me that you are still using Microsoft.EntityFramework, not Microsoft.EntityFrameworkCore, hence the error. When you install Microsoft.EntityFrameworkCore, Microsoft.Extensions.DepedencyInkection.Abstractions in included in the Nuget package.
Norman Yuan
Drive CAD With Code
mdoyon1
Thank you!
AutoCAD Inside the Factory
