Check if there are any unresolved references
smx_khang
smx_khang
Hello everyone,
How do I check if there are any unresolved references in the drawing?
(A function similar to the AutoCAD built-in: see below image)
_gile
You can iterate through the BlockTable and, foreach BlockTableRecord it contains, check for the values of th IsFromExternalReference and the XrefStatus properties (see the XrefStatus enum).
Gilles Chanteau
GileCAD
GitHub
smx_khang
Hi @_gile
Thank you and sorry for my late response.
I successully checked xref of a dwg. But other xref types, for example: `UnderlayReference` or `RasterImage` does not represented as a BlockTableRecord.
How can I check these types of references?
Best regards
_gile
Have a look at the UnderlayDefinition properties and RasterImageDef properties.
You should use a snoop tool such as MgdDbg or Inspector.
Gilles Chanteau
GileCAD
GitHub
smx_khang
Thank you @_gile
They are really useful tools!
