Change activedocument
Message 1 of 10
I'm running a command from an original drawing to open a another drawingand apply some edits to it. I open the newdrawing with;
Dim FileName As String = "C:\XXX.dwg"
Dim acDocMgr As DocumentCollection = Application.DocumentManager
Dim opdoc As Document = DocumentCollectionExtension.Open(acDocMgr, FileName)
then when I run the editing code after this code it applies the edits to original drawing, as I believe this is still the active drawing - my question is what is the best way apply these edits to the new just opened drawing? Can I switch the active document to the new drawing...? Or is there another way?
Harry
Accepted solutions (3)
Replies (9)
Message 2 of 10
hi
did u try after opening the drawing to put
opdoc = Application.DocumentManager.MdiActiveDocument
Message 3 of 10
yeh, should have said, that is the next line in the current script
Message 4 of 10
So i thought if I try and close the original drawing before opening the new one with;
Dim doccol As DocumentCollection = Application.DocumentManager
DocumentCollectionExtension.CloseAll(doccol)
It might automatically set the new drawing it opens as the "activedocument"
Buuuut that didn't work, it can't close it throwing an error saying "document is busy"
Message 5 of 10
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            CloseAndDiscard(doc)
            doc = Nothing
works in my skript just fine
but even this will work it is just a workaround and in the end would not realy serve ur goal
have a look on this threat http://forums.autodesk.com/t5/net/how-to-switch-between-multiple-open-documents/td-p/3724860
maybe it solves ur problem
it just came to my mind: did u set commandflag.session?
Message 6 of 10
mmm, tried a few things with this;
Application.DocumentManager.DocumentActivationEnabled = True
As I understand it this enables a new doc to be activated when a new window has been opended but doesn't seem to get any better results;
Here is the code im using can you see any glaring errors?;
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.GraphicsInterface
Imports Autodesk.AutoCAD.Runtime
Imports System.Collections.Generic
Namespace CustomMove
Public Class Commands
<CommandMethod("copymove", CommandFlags.UsePickSet)> _
Public Shared Sub CustomMoveCmd()
Dim FileName As String = "C:\xxxx.dwg"
Dim opdoc As Document = DocumentCollectionExtension.Add(acDocMgr, FileName)
'opdoc = Application.DocumentManager.MdiActiveDocument
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
etc....
Message 7 of 10
Do you think it could be something to do with the command flag?
Message 8 of 10
yes i think so
u need commandflag.session when u want change something outside a specific document (if u want for ex open close or add documents)
Message 9 of 10
norman.yuan
In your paticular case, you need to set CommandFlas.Session flag (along with others, if necessary and suitable).
Norman Yuan
Drive CAD With Code
Message 10 of 10
Hi harry
I just found a nice way to swich between different databases!
use:
HostApplicationServices.WorkingDatabase = db 'the database u want to swich to
hope this solves ur problem
PS: u dont need to set sessionflags.session for this to work 😉
