Catching command window output with .NET-api
ottosson_mathias
Message 1 of 8
ottosson_mathias
Are there any way of catching the command window history/text in AutoCAD using the .NET API? I would like to be able to save it for debugging purposes.
Replies (7)
Message 2 of 8
_gile
You can play with the LOGFILEMODE and LOGFILENAME system variables.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
ottosson_mathias
Thanks. (Just fyi, both links goes to LOGFILEMODE)
So no api-access? I would like to analyze it in real-time in my add-in, and reading from a file feels a bit awkward.
Message 4 of 8
Alexander.Rivilis
It is possible with ObjectARX: https://adndevblog.typepad.com/autocad/2012/09/trapping-the-output-from-the-autocad-text-screen-comm...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 5 of 8
jabowabo
Autodesk.AutoCAD.Internal.Utils.GetLastCommandLines(int, bool)
Example:
int lineCount = 20;
bool ignoreNull = true;
string cmds = "";
List<string> cmdLineList = Autodesk.AutoCAD.Internal.Utils.GetLastCommandLines(lineCount, ignoreNull);
cmdLineList.Reverse();
foreach (string str in cmdLineList)
  cmds += str + Environment.NewLine;
MessageBox.Show(cmds);
Message 6 of 8
ottosson_mathias
Thanks @jabowabo, I'll try it in the coming days.
Bonus question: Is it possible to get all the lines, not just a fixed amount?
Message 7 of 8
jabowabo
The method takes an int parameter so you'll have to supply something. You could just give it a very high number like 999999 (unless you think you'll have more than a million lines 😜)
Message 8 of 8
ottosson_mathias
This works.
Thanks a lot!
