Announcements
Cannot access screen or entities after insertion
js75CAD
js75CAD
I am embarrassed to ask this, but I need help...
I insert a block using .Net. That's ok, but after the block is inserted I am unable to select anything on the screen and I mean anything! I need to hit the escape button and then regen in order to be able to select the block.
I have tried:
Dim brefIds As ObjectIdCollection = btr.GetBlockReferenceIds(False, True)
                            For Each id As ObjectId In brefIds
                                Dim bref As BlockReference = tr.GetObject(id, OpenMode.ForWrite, False, True)
                                bref.RecordGraphicsModified(True)
                            Next
Also:
tr.TransactionManager.QueueForGraphicsFlush()
But to no avail! Why am I not able to access anything until escaping and regen? It is driving me crazy. Basically, I have a floating Pallette that calls up this command:
        <CommandMethod("UDC_TPInsert")> Public Shared Sub InsertBlocks()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim ed As Editor = doc.Editor
            Dim blkName As String = My.Settings.BlockName
            Dim blkLay As String = My.Settings.BlockScale
            Dim bSc As Double = My.Settings.BlockLayer
            Dim cLay As String = Nothing
            Dim ObjId As ObjectId
            Dim pr As PromptResult
            Dim dRot As Double
            Dim attrot As Double = 0
            Dim info As DatabaseSummaryInfo = db.SummaryInfo
            Dim blkRecId As ObjectId = ObjectId.Null
            Dim iPt1(0 To 2) As Double
            Dim ipt3d As Point3d
            Dim tp As Integer = 0
            Dim iSNewBlk As Boolean = False
            Dim newblk As ObjectId = Nothing
            Using doc.LockDocument
                Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
                Try
                    Dim sScale As Double = bSc
                    Dim cs As Double = CDbl(My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCScale", Nothing))
                    If String.IsNullOrEmpty(bSc) Or bSc = 0 Then sScale = cs
                    Dim sOrient As String = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCOrient", Nothing)
                    Dim sfile As String = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCDATA", Nothing)
                    sfile = Path.GetFileName(sfile)
                    Dim xmlList As New List(Of String)
                   Dim bSL As Boolean = False
                    Using tr As Transaction = db.TransactionManager.StartTransaction
                        ' CHECK IF THE BLOCK EXISTS IIN THE DRAWING ELSE INSERT IT
                        Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                        CheckorMakelayer(blkLay, 7)
                        If Not bt.Has(blkName) Then
                            iSNewBlk = True
                            If ImportBlocks(blkName) = False Then
                                Try
                                    Dim BlkFullPath = funcFFile(blkName)
                                    Using dbInsert As New Database(False, True)
                                        dbInsert.ReadDwgFile(BlkFullPath, IO.FileShare.Read, True, "")
                                        ObjId = db.Insert(Path.GetFileNameWithoutExtension(BlkFullPath), dbInsert, True)
                                    End Using
                                Catch ex As System.Exception
                                    ed.WriteMessage(vbLf & "Block '{0}' not found.", blkName)
                                    Return
                                End Try
                            ObjId = bt(blkName)
                        Else
                            ObjId = bt(blkName)
                        ' NOW INSERT THE BLOCK
                        Using br As New BlockReference(Point3d.Origin, ObjId)
                            br.Layer = blkLay
                            br.TransformBy(ed.CurrentUserCoordinateSystem)
                            If Not bSc = 0 Then sScale = bSc
                            Dim insertJig As New UDC_Common.InsertBlockJig.InsertBlockJig(br, bSc)
                            pr = ed.Drag(insertJig)
                            ' Using RotateBlockJig class to rotate the block
                            Dim rotateJig As New UDC_Common.InsertBlockJig.RotateBlockJig(br)
                            pr = ed.Drag(rotateJig)
                            rotateJig.UpdateRotation()
                            dRot = br.Rotation
                            ' Check if it is a streetlight and move it back
                            For Each it In xmlList
                                If UCase(it).Equals(UCase(br.Name)) Then
                                    bSL = True
                                    Exit For
                                Else
                                    bSL = False
                            Next
                            'ed.WriteMessage(vbLf & bSL)
                            Select Case bSL
                                Case True
                                    Dim sla As String = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCSLA", Nothing)
                                    Dim slo As Single = CSng(My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCOffset", Nothing))
                                    dRot = Format(dRot - funcGetRads(90), "0.000000")
                                    If sla = "T" Then
                                        iPt1(0) = insertJig.iPt.X + (Math.Sin(dRot) * slo) : iPt1(1) = insertJig.iPt.Y - (Math.Cos(dRot) * slo)
                                        ipt3d = New Point3d(iPt1(0), iPt1(1), 0)
                                        br.Position = ipt3d
                                    Else
                                        ipt3d = New Point3d(insertJig.iPt.X, insertJig.iPt.Y, 0)
                                    'ObjId = funcInsBlkAtts(db, "LV_POLE", ipt3d, "", dRot)
                                    dRot = 0
                            End Select
                            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                            btr.AppendEntity(br)
                            tr.AddNewlyCreatedDBObject(br, True)
                            Select Case sOrient
                                Case "A" : attrot = dRot
                                Case Else : attrot = funcGetRads(sOrient)
                            End Select
                            'blkRecId = bt(sspl(UBound(sspl)))
                            blkRecId = bt(blkName)
                            If blkRecId <> ObjectId.Null Then
                                Dim BlkTblRec As BlockTableRecord = TryCast(tr.GetObject(blkRecId, OpenMode.ForRead), BlockTableRecord)
                                If BlkTblRec.HasAttributeDefinitions Then
                                    For Each objId2 As ObjectId In BlkTblRec
                                        Dim AttDef As AttributeDefinition = TryCast(tr.GetObject(objId2, OpenMode.ForRead), AttributeDefinition)
                                        If AttDef IsNot Nothing Then
                                            Dim AttRef As New AttributeReference()
                                            AttRef.SetAttributeFromBlock(AttDef, br.BlockTransform)
                                            AttRef.Rotation = attrot
                                            br.AttributeCollection.AppendAttribute(AttRef)
                                            tr.AddNewlyCreatedDBObject(AttRef, True)
                                    Next
                            'MsgBoxWithLineNumber("TP")
                            Next
                            newblk = br.ObjectId
                        End Using
                        If iSNewBlk = True Then
                            '' Example of grabbing a single block object id from the database
                            'Dim btrId As ObjectId = db.Insert(blkName, db, True)
                            Dim brcsdxgfdgf = CType(tr.GetObject(newblk, OpenMode.ForRead), BlockReference)
                            WipeoutsToBottom(brcsdxgfdgf)
                        tr.Commit()
                    End Using
                    doc.SendStringToExecute("UDC_TPInsert", True, False, False)
                    ed.WriteMessage(ex.Message)
                End Try
            End Using
        End Sub
Is there anyone who might be able to explain what I am doing wrong?
js75CAD
Ok, I have nailed it down to this command!
Why is this taking the focus off of the drawing and how the hell do I get back? I have tried using :
But to no avail...
@BlackBox_ helped me find this command, but I am unable to determine why it takes the focus away from the Active drawing and how to get it back. I have changed the values to True, but all I get is an error.
So frustrating!
_gile
what do you expect when doing this:
        End Sub
You define a Command which calls itself...
Gilles Chanteau
GileCAD
GitHub
js75CAD
_gile,
At first I was going to go on the defence, but I know your intentions are good, so, mate thank you.
My intention was to be able to repeat the command, so when I was advised to use that method, I was not helped to understand, which I am hoping you might do.
The command doesn't actually run, but stores it, so may I ask why you can't have it within the command itself? To the best of my understanding it merely logs it so when I hit return it repeats, but I do not understand why it can't. Obviously it is doing something, but it eludes me.
Thank you by the way, it now works.
