Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I am embarrassed to ask this, but I need help...
I insert a block using .Net. That's ok, but after the block is inserted I am unable to select anything on the screen and I mean anything! I need to hit the escape button and then regen in order to be able to select the block.
I have tried:
Dim brefIds As ObjectIdCollection = btr.GetBlockReferenceIds(False, True)
For Each id As ObjectId In brefIds
Dim bref As BlockReference = tr.GetObject(id, OpenMode.ForWrite, False, True)
bref.RecordGraphicsModified(True)
Next
Also:
tr.TransactionManager.QueueForGraphicsFlush()
But to no avail! Why am I not able to access anything until escaping and regen? It is driving me crazy. Basically, I have a floating Pallette that calls up this command:
<CommandMethod("UDC_TPInsert")> Public Shared Sub InsertBlocks()
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim ed As Editor = doc.Editor
Dim blkName As String = My.Settings.BlockName
Dim blkLay As String = My.Settings.BlockScale
Dim bSc As Double = My.Settings.BlockLayer
Dim cLay As String = Nothing
Dim ObjId As ObjectId
Dim pr As PromptResult
Dim dRot As Double
Dim attrot As Double = 0
Dim info As DatabaseSummaryInfo = db.SummaryInfo
Dim blkRecId As ObjectId = ObjectId.Null
Dim iPt1(0 To 2) As Double
Dim ipt3d As Point3d
Dim tp As Integer = 0
Dim iSNewBlk As Boolean = False
Dim newblk As ObjectId = Nothing
Using doc.LockDocument
Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
Try
Dim sScale As Double = bSc
Dim cs As Double = CDbl(My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCScale", Nothing))
If String.IsNullOrEmpty(bSc) Or bSc = 0 Then sScale = cs
Dim sOrient As String = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCOrient", Nothing)
Dim sfile As String = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCDATA", Nothing)
sfile = Path.GetFileName(sfile)
Dim xmlList As New List(Of String)
Dim bSL As Boolean = False
Using tr As Transaction = db.TransactionManager.StartTransaction
' CHECK IF THE BLOCK EXISTS IIN THE DRAWING ELSE INSERT IT
Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
CheckorMakelayer(blkLay, 7)
If Not bt.Has(blkName) Then
iSNewBlk = True
If ImportBlocks(blkName) = False Then
Try
Dim BlkFullPath = funcFFile(blkName)
Using dbInsert As New Database(False, True)
dbInsert.ReadDwgFile(BlkFullPath, IO.FileShare.Read, True, "")
ObjId = db.Insert(Path.GetFileNameWithoutExtension(BlkFullPath), dbInsert, True)
End Using
Catch ex As System.Exception
ed.WriteMessage(vbLf & "Block '{0}' not found.", blkName)
Return
End Try
End If
ObjId = bt(blkName)
Else
ObjId = bt(blkName)
End If
' NOW INSERT THE BLOCK
Using br As New BlockReference(Point3d.Origin, ObjId)
br.Layer = blkLay
br.TransformBy(ed.CurrentUserCoordinateSystem)
If Not bSc = 0 Then sScale = bSc
Dim insertJig As New UDC_Common.InsertBlockJig.InsertBlockJig(br, bSc)
pr = ed.Drag(insertJig)
' Using RotateBlockJig class to rotate the block
Dim rotateJig As New UDC_Common.InsertBlockJig.RotateBlockJig(br)
pr = ed.Drag(rotateJig)
rotateJig.UpdateRotation()
dRot = br.Rotation
' Check if it is a streetlight and move it back
For Each it In xmlList
If UCase(it).Equals(UCase(br.Name)) Then
bSL = True
Exit For
Else
bSL = False
End If
Next
'ed.WriteMessage(vbLf & bSL)
Select Case bSL
Case True
Dim sla As String = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCSLA", Nothing)
Dim slo As Single = CSng(My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\UserVars", "BCOffset", Nothing))
dRot = Format(dRot - funcGetRads(90), "0.000000")
If sla = "T" Then
iPt1(0) = insertJig.iPt.X + (Math.Sin(dRot) * slo) : iPt1(1) = insertJig.iPt.Y - (Math.Cos(dRot) * slo)
ipt3d = New Point3d(iPt1(0), iPt1(1), 0)
br.Position = ipt3d
Else
ipt3d = New Point3d(insertJig.iPt.X, insertJig.iPt.Y, 0)
End If
'ObjId = funcInsBlkAtts(db, "LV_POLE", ipt3d, "", dRot)
dRot = 0
End Select
Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
btr.AppendEntity(br)
tr.AddNewlyCreatedDBObject(br, True)
Select Case sOrient
Case "A" : attrot = dRot
Case Else : attrot = funcGetRads(sOrient)
End Select
'blkRecId = bt(sspl(UBound(sspl)))
blkRecId = bt(blkName)
If blkRecId <> ObjectId.Null Then
Dim BlkTblRec As BlockTableRecord = TryCast(tr.GetObject(blkRecId, OpenMode.ForRead), BlockTableRecord)
If BlkTblRec.HasAttributeDefinitions Then
For Each objId2 As ObjectId In BlkTblRec
Dim AttDef As AttributeDefinition = TryCast(tr.GetObject(objId2, OpenMode.ForRead), AttributeDefinition)
If AttDef IsNot Nothing Then
Dim AttRef As New AttributeReference()
AttRef.SetAttributeFromBlock(AttDef, br.BlockTransform)
AttRef.Rotation = attrot
br.AttributeCollection.AppendAttribute(AttRef)
tr.AddNewlyCreatedDBObject(AttRef, True)
End If
Next
End If
End If
'MsgBoxWithLineNumber("TP")
Next
newblk = br.ObjectId
End Using
If iSNewBlk = True Then
'' Example of grabbing a single block object id from the database
'Dim btrId As ObjectId = db.Insert(blkName, db, True)
Dim brcsdxgfdgf = CType(tr.GetObject(newblk, OpenMode.ForRead), BlockReference)
WipeoutsToBottom(brcsdxgfdgf)
End If
tr.Commit()
End Using
doc.SendStringToExecute("UDC_TPInsert", True, False, False)
ed.WriteMessage(ex.Message)
End Try
End Using
End Sub
Is there anyone who might be able to explain what I am doing wrong?
Solved by _gile. Go to Solution.
Ok, I have nailed it down to this command!
Why is this taking the focus off of the drawing and how the hell do I get back? I have tried using :
But to no avail...
@BlackBox_ helped me find this command, but I am unable to determine why it takes the focus away from the Active drawing and how to get it back. I have changed the values to True, but all I get is an error.
So frustrating!
what do you expect when doing this:
End Sub
You define a Command which calls itself...
_gile,
At first I was going to go on the defence, but I know your intentions are good, so, mate thank you.
My intention was to be able to repeat the command, so when I was advised to use that method, I was not helped to understand, which I am hoping you might do.
The command doesn't actually run, but stores it, so may I ask why you can't have it within the command itself? To the best of my understanding it merely logs it so when I hit return it repeats, but I do not understand why it can't. Obviously it is doing something, but it eludes me.
Thank you by the way, it now works.
