can't stretch ComboBox with StackPanel
J-Rocks
Message 1 of 8
J-Rocks
I can't stretch ComboBox & TextBox when I add them into StackPanel to be in one line.
I can control the ComboBox if it is outside StackPanel otherwise properites can not effect them while they are in StackPanel.
Is there any solution for this problem?
Thanks in advance.
    <Grid>
        <StackPanel >
            <StackPanel Orientation="Horizontal">
                <TextBox x:Name="TextBox1" Width="65"></TextBox>
                <ComboBox x:Name="ComboBox1" Height="22" SelectedIndex="0"></ComboBox>
            </StackPanel>
        </StackPanel>
    </Grid>
Replies (7)
Message 2 of 8
_gile
Did you try using a Grid instead ?
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
_gile
Something like this:
    <Grid>
        <StackPanel >
            <Grid>
                <Grid.ColumnDefinitions>
                    <ColumnDefinition Width="Auto"/>
                    <ColumnDefinition Width="*"/>
                </Grid.ColumnDefinitions>
                <TextBox x:Name="TextBox1" Grid.Column="0" Width="65" Margin="5"/>
                <ComboBox x:Name="ComboBox1" Grid.Column="1" Height="22" Margin="5" SelectedIndex="0"></ComboBox>
            </Grid>
        </StackPanel>
    </Grid>
PS: with WPF, it's a good practice to avoid naming the controls and use bindings instead.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
J-Rocks
Hi gile,
I think it is the same without stretching to right at all.
    <Grid>
        <Grid HorizontalAlignment="Left" VerticalAlignment="Top" >
                <TextBox x:Name="TextBox1" Margin="0,0,0,0" Width="65" Height="22"></TextBox>
                <ComboBox x:Name="ComboBox1" Margin="65,0,-175,0" Height="22" SelectedIndex="0" HorizontalAlignment="Stretch"></ComboBox>
       </Grid>
   </Grid>
Message 5 of 8
_gile
A Grid is quite useless until you do not define ColumnDefinitions and/or RowDefinitions.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 8
J-Rocks
Very good ,
Binding is something over my head now, and it could be the next thing to learn soon.
What's if I waned to add a new TextBox below the first grid and make it stretch as well as the comboBox ?
Thank you.
Message 7 of 8
_gile
You can use a StackPanel with default Orientation (i.e. Vertical)
    <StackPanel >
        <Grid>
        </Grid>
        <TextBox x:Name="TextBox2" Grid.Column="0" Margin="5" HorizontalAlignment="Stretch"/>
    </StackPanel>
Or a Grid
    <Grid>
        <Grid.RowDefinitions>
            <RowDefinition Height="Auto"/>
        </Grid.RowDefinitions>
        <Grid Grid.Row="0">
        </Grid>
        <TextBox Grid.Row="1" x:Name="TextBox2" Grid.Column="0" Margin="5"/>
    </Grid>
You should read almost this about WPF containers.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
J-Rocks
Your beautiful examples encouraged me to read and do more examples with Grid ,StackPanel .... Containers in general.
Many thanks gile
