Can not hit breakpoint while debuging
viper_007
viper_007
Hi, I've been learning AutoCAD .NET API for several days. There's a strange problem confused me. I can't hit the breakpoint in any VS solution about AutoCAD .net api while I'm debugging.
Here's my development environment: Win 7 64bit, VS 2013, AutoCAD Map 3D 2011.
Looking forward to your help!
聚傲气于一身,显傲骨之精华
norman.yuan
You did not say, but I 'd guess that the breakpoint is placed in code of a UI, such as Windows form/usercontrol.
You need to disable "FIBER" by entering command "NEXTFIBERWORLD" and set it vale to 0 and restart AutoCAD session. For more information, search Kean's blog for "Fiber"
Norman Yuan
Drive CAD With Code
viper_007
No, I just write some simple function and command in class, not in forms or usercontrols.
Anyway, I've tried to set the value of "NEXTFIBERWORLD" to 0. But when I start the cad application, it prompts a dialogbox  asking me to select "_MAPDMDWGLOADED.shx". I cannot find the shx, so I click Cancel button, and then the cad application will be not responding until I end the process in the taskmanager.
Now the question is, I don't have the chance to set "NEXTFIBERWORLD" back to 1, what should I do?
Thank you all the same.
聚傲气于一身,显傲骨之精华
I've never heard of this "fiber" solution..
It's all explained here:
http://through-the-interface.typepad.com/through_the_interface/2013/11/debugging-autocad-using-visua...
viper_007
I've got a nice solution to my problem.
Look at this page: Hitting breakpoints in .NET Class Libraries while debugging with Visual Studio 2010
There're three method, I like the last one.
聚傲气于一身,显傲骨之精华
