I have a list of line objects stored in RAM and I want to see if any of them (one always will be) are parallel to a seperate line object which is also already on RAM so I don't have to read them from the database. I also have another line object that will cross the parallel line from the list but start at the beginning of the separate line and end at the opposite side of the line from the list as shown in the image below. List line is red and the two comparisons lines are green.
it will add the line that is parallel but only when its partner intersects to a concurrentbag. The problem I get is that it either does not find a value or it finds a value and repeats that line 162 times (the amount of lines I have in the list). It is random if does or does not find a result. I tied using a regular loop and it has the same problem. Not sure where I am going wrong.
using System;
using System.Collections.Generic;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.Collections.Concurrent;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
namespace placePillars.Place_Cables
class CableIntersects
public static (Line, ObjectId) IntersectingCables(Document doc, Editor ed, Database db, List<Line> lineList, Line innerLine, Line outerLine)
//Assume the line is correct, ie y2-y
bool innerbackwars = false;
bool outerbackwars = false;
bool linebackwards = false;
Double mBoundary;
Double bBoundary;
Double mInner;
Double mOuter;
double tolerance = 0.01;
ConcurrentBag<Line> newCable = new ConcurrentBag<Line>();
ObjectId cableIntersect = new ObjectId();
Line newcableResult = new Line();
//Check where the start point is in regards to the end point
if (innerLine.EndPoint.X - innerLine.StartPoint.X < 0)
//start point is after end point
innerbackwars = true;
if (outerLine.EndPoint.X - outerLine.StartPoint.X < 0)
outerbackwars = true;
//Workout gradient of unchanging lines
if (innerbackwars == false)
mInner = (innerLine.EndPoint.Y - innerLine.StartPoint.Y) / (innerLine.EndPoint.X - innerLine.StartPoint.X);
else
mInner = (innerLine.StartPoint.Y - innerLine.EndPoint.Y) / (innerLine.StartPoint.X - innerLine.EndPoint.X);;
if (outerbackwars == false)
mOuter = (outerLine.EndPoint.Y - outerLine.StartPoint.Y) / (outerLine.EndPoint.X - outerLine.StartPoint.X);
else
mOuter = (outerLine.StartPoint.Y - outerLine.EndPoint.Y) / (outerLine.StartPoint.X - outerLine.EndPoint.X);
//Workout y axis intersect (where x=0)
Double bInner = innerLine.StartPoint.Y - mInner * innerLine.StartPoint.X;
Double bOuter = outerLine.StartPoint.Y - mOuter * outerLine.StartPoint.X;
try
//using (DocumentLock acLckDoc = doc.LockDocument())
//using (Transaction acTrans = db.TransactionManager.StartTransaction())
//Check for parallel lines first
//Parallel.ForEach(lineList, (lineRecord) =>
foreach(Line lineRecord in lineList)
bool inner = false;
bool outer = false;
if (lineRecord.EndPoint.X - lineRecord.StartPoint.X < 0)
linebackwards = true;
//Workout gradients of the lines
if (linebackwards == false)
mBoundary = (lineRecord.EndPoint.Y - lineRecord.StartPoint.Y) / (lineRecord.EndPoint.X - lineRecord.StartPoint.X);
else
mBoundary = (lineRecord.StartPoint.Y - lineRecord.EndPoint.Y) / (lineRecord.StartPoint.X - lineRecord.EndPoint.X);
bBoundary = lineRecord.StartPoint.Y - mBoundary * lineRecord.StartPoint.X;
//test to see if innter out outer intersect
//Check to see if they are parallel to reduce calculations
//y=xm+b ---> xm+b=y=xm+b ---> x=x (move x to LHS) ---> x+x(-1)
var x = mBoundary + mInner * -1;
var b = bBoundary * -1 + bInner;
if (x <= tolerance && x >= -tolerance) x = 0;
double x1 = (float)b / (float)x;
x = mBoundary + mOuter * -1;
b = bBoundary * -1 + bOuter;
double x2 = (float)b / (float)x;
var _y = lineRecord.Handle.Value;
if (_y==67397683)
var _u = 1;
//If X1 is the intercept line then we want to look at ir whilst X2 = inf
if (!double.IsInfinity(x1) && double.IsInfinity(x2))
//Dont know if line start or end comes first on x axis so work it out based on line length from x=0
if (innerbackwars == true)
if (x1 < innerLine.StartPoint.X && x1 > innerLine.EndPoint.X)
//if inner line intercepts then we want the outer as our cable
outer = true;
if (x1 > innerLine.StartPoint.X && x1 < innerLine.EndPoint.X)
outer = true;
//if (inner == true && outer == false) break;
//Now see if outer cable intersects
if (double.IsInfinity(x1) && !double.IsInfinity(x2))
if (x2 < outerLine.StartPoint.X && x2 > outerLine.EndPoint.X)
inner = true;
if (outerbackwars == true)
if (x2 > outerLine.StartPoint.X && x2 < outerLine.EndPoint.X)
inner = true;
if ((inner == true && outer == false) || (inner == false && outer == true))
if (inner == true)
newCable.Add(innerLine);
cableIntersect = outerLine.ObjectId;
inner = false;
outer = false;
else
newCable.Add(outerLine);
cableIntersect = innerLine.ObjectId;
inner = false;
outer = false;
}//);//End of loop
var newcacleCount = newCable.Count;
if (newcacleCount == 0)
var _a = 1;
//if (newcacleCount > 1) { }
else
foreach(var item in newCable)
newcableResult = item;
catch (System.Exception ex)
MessageBox.Show(ex.StackTrace);
MessageBox.Show(ex.Source);
return (newcableResult, cableIntersect) ;
