.NET
Cad Add-in Manager
2 REPLIES 2
Ahmmed-saber
126 Views, 2 Replies
Cad Add-in Manager
i downloaded CadAddInManager to check the dlll file , without close & re-open Autocad or Civil3D each time from this link
but this message show when running the command AddInManager Manual from civil 3D 2025
any one help for this problem
2 REPLIES 2
ed57gmc
in reply to: Ahmmed-saber
I don't see the missing library in his repository. If you can find the dll on your hard drive, you can click on the LOAD button. Otherwise, I suggest you contact the author.
Ed
How to post your code.
This may help
https://github.com/search?q=repo%3Achuongmep%2FCadAddinManager%20Mono&type=code
https://www.mono-project.com/docs/tools+libraries/libraries/Mono.Cecil/
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
Sometimes the question is more important than the answer.
class keyThumper<T> : Lazy<T>;      another  Swamper
AutoCAD Inside the Factory
