C# .NET Document SaveAs
oransen
oransen
I must have forgotten to twiddle a lever or push a button somewhere...
oransen
Ooops. Forget it. I must study more. Here's the code I got to work.
            using (Database db = new Database(false, true))
                db.ReadDwgFile(sSourceFullFileName, FileOpenMode.OpenForReadAndReadShare, false, "");
                // closing the input makes sure the whole dwg is read from disk
                // it also closes the file so you can SaveAs the same name
                db.CloseInput(true);
                // store the current working database, to reset
                Database currDb = HostApplicationServices.WorkingDatabase;
                // set working database
                HostApplicationServices.WorkingDatabase = db;
                // { Do Some Work}
                db.SaveAs(sFullDestFileName, DwgVersion.Current);
                // reset the working database
                HostApplicationServices.WorkingDatabase = currDb;
I picked it up in a desperate search in the forums...
