C# Cannot Convert
C# Cannot Convert
Message 1 of 10
C# Cannot Convert
Hi everybody i'm coding in C#, and i referenced the : using Autodesk.AutoCAD.Interop; using Autodesk.AutoCAD.Interop.Common; But when i Run the code i get thoses errors in the attached image
Replies (9)
Message 2 of 10
Got these errors : Error 5 Argument 1: cannot convert from 'Autodesk.AutoCAD.Interop.AcadDocument [h:\CESBRON\Traceur\SmoothProgressBar.cs]' to 'Autodesk.AutoCAD.Interop.AcadDocument' H:\CESBRON\Traceur\Dessin.cs 53 52 Traceur Error 7 Argument 1: cannot convert from 'Autodesk.AutoCAD.Interop.AcadDocument [h:\CESBRON\Traceur\SmoothProgressBar.cs]' to 'Autodesk.AutoCAD.Interop.AcadDocument' H:\CESBRON\Traceur\Dessin.cs 123 52 Traceur Error 9 Argument 1: cannot convert from 'Autodesk.AutoCAD.Interop.AcadDocument [h:\CESBRON\Traceur\SmoothProgressBar.cs]' to 'Autodesk.AutoCAD.Interop.AcadDocument' H:\CESBRON\Traceur\Dessin.cs 170 52 Traceur Error 12 Argument 1: cannot convert from 'Autodesk.AutoCAD.Interop.AcadDocument [h:\CESBRON\Traceur\SmoothProgressBar.cs]' to 'Autodesk.AutoCAD.Interop.AcadDocument' H:\CESBRON\Traceur\Doc.cs 205 30 Traceur Error 3 Argument 1: cannot convert from 'ref Autodesk.AutoCAD.Interop.AcadSelectionSet [h:\CESBRON\Traceur\SmoothProgressBar.cs]' to 'ref Autodesk.AutoCAD.Interop.AcadSelectionSet' H:\CESBRON\Traceur\Automation.cs 42 43 Traceur Error 1 The best overloaded method match for 'DLLSelectionSet.SelectSelectionSet.SelectSSet(ref Autodesk.AutoCAD.Interop.AcadSelectionSet)' has some invalid arguments H:\CESBRON\Traceur\Automation.cs 42 9 Traceur Error 4 The best overloaded method match for 'GetPointCoord.GetPointCoord.GetPoint(Autodesk.AutoCAD.Interop.AcadDocument, ref object, ref object)' has some invalid arguments H:\CESBRON\Traceur\Dessin.cs 53 9 Traceur Error 6 The best overloaded method match for 'GetPointCoord.GetPointCoord.GetPoint(Autodesk.AutoCAD.Interop.AcadDocument, ref object, ref object)' has some invalid arguments H:\CESBRON\Traceur\Dessin.cs 123 9 Traceur Error 8 The best overloaded method match for 'GetPointCoord.GetPointCoord.GetPoint(Autodesk.AutoCAD.Interop.AcadDocument, ref object, ref object)' has some invalid arguments H:\CESBRON\Traceur\Dessin.cs 170 9 Traceur Error 11 The best overloaded method match for 'GetPointCoord.GetPointCoord.GetPoint(Autodesk.AutoCAD.Interop.AcadDocument, ref object, ref object)' has some invalid arguments H:\CESBRON\Traceur\Doc.cs 205 7 Traceur Error 10 The type 'Autodesk.AutoCAD.Interop.AcadDocument' is defined in an assembly that is not referenced. You must add a reference to assembly 'Autodesk.AutoCAD.Interop, Version=18.0.0.0, Culture=neutral, PublicKeyToken=eed84259d7cbf30b'. H:\CESBRON\Traceur\Doc.cs 201 7 Traceur Error 2 The type 'Autodesk.AutoCAD.Interop.AcadSelectionSet' is defined in an assembly that is not referenced. You must add a reference to assembly 'Autodesk.AutoCAD.Interop, Version=18.0.0.0, Culture=neutral, PublicKeyToken=eed84259d7cbf30b'. H:\CESBRON\Traceur\Automation.cs 42 9 Traceur This is my Github : https://github.com/borisdagnon/CESBRON/tree/master/Traceur
Message 3 of 10
_gile
You have to compile your project and all its home made dependant libraries against the same AutoCAD.Interop version libraries (i.e. the AutoCAD version you're targeting).
Gilles Chanteau
GileCAD
GitHub
Message 4 of 10
I'm targeting Autocad 2016 and i referenced all the dll of the 2016 version. But i'm still having a problem with Error 2 The type 'Autodesk.AutoCAD.Interop.AcadSelectionSet' is defined in an assembly that is not referenced. You must add a reference to assembly 'Autodesk.AutoCAD.Interop, Version=18.0.0.0, Culture=neutral, PublicKeyToken=eed84259d7cbf30b'. H:\CESBRON\Traceur\Automation.cs 42 9 Traceur I don't know what to change, when i replace by the Autocad 2010 assemblies it does work. A very confusing problem
Message 5 of 10
norman.yuan
You may want to provide more details on not only what versio of AutoCAD you are targeting and what versio of AutoCAD you ARE USING for your developing/debugging.
To me, it looks like you are running older version of AutoCAD (older than AutoCAD 2016) in your debugging. That is why you cannot use new version of AutoCAD COM Interop assembly. Your developing/debugging AutoCAD cannot be newer COM interop assembly. You should use the same version of Interop assembly as your running AutoCAD for your development. And yes, your application developed for the older version of AutoCAD would likely run OK with newer version of AutoCAD, as long as the CAD features used in your application are not broken by newer AutoCAD, which happens very rarely (but do happen from version to version occassionally, or intentionally).
Targeting multiple versions of AutoCAD is always risky, In general, your best bet is to use the same version as the target version for your development.
Norman Yuan
Drive CAD With Code
Message 6 of 10
I found the solution 😄 I have to decompile the GetPointCoord.dll and DLLSelectionset.dll with JetBrains or another decompiler and change the using Autodesk.AutoCAD.Interop; using Autodesk.AutoCAD.Interop.Common with the 2016 version dll and recompile GetPointCoord.dll and DLLSelectionset.dll. After that i went in my Traceur project and referenced the two dlls. Thank you About _gile 😄 you were righ but i didn't understood at the moment.
Message 7 of 10
kerry_w_brown
Who is the author of the GetPointCoord.dll and DLLSelectionset.dll that you decompiled ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 8 of 10
I don't realy now, when i search for, i dind't foud anyone. But according to what you're saying how do i have to compile the dlls without decompiling the dlls ?
Message 9 of 10
dgorsman
I think the point was de-compiling/disassembling somebody else's code without permission is at best frowned upon, and at worst legally actionable.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 10 of 10
I'm part of a society and the dlls were developed by a worker of our organization don't mind everything is alright, i'm not a hacker guys :-D.
