batch xref bind vb.net
yoitsarun
Message 1 of 16
yoitsarun
i tried to batch bind xrefs but getting "invalid input error"
could any one please help me please:
Namespace FormVB
    Public Class RunApp
        <autodesk.autocad.runtime.commandmethod("bxb", autodesk.autocad.runtime.commandflags.session)="">
        Public Shared Sub InitForm()
            Dim frm As New BatchXrefBind
            Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
              Dim result As DialogResult = Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(frm)
        End Sub
    End Class
End Namespace
Public Class BatchXrefBind
    Private Sub button_Publish_Click(sender As Object, e As EventArgs) Handles button_Publish.Click
                Dim openFile1 As OpenFileDialog = New OpenFileDialog()
               openFile1.InitialDirectory = "C\"
        openFile1.Filter = "Drawing Files|*.dwg"
        openFile1.Multiselect = True
                If openFile1.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
            If openFile1.FileNames.Length > 0 Then
                Dim strFile As String
                For Each strFile In openFile1.FileNames
 Using db As Database = New Database(False, True)
                        db.ReadDwgFile(strFile, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
 Dim bTransMan As DatabaseServices.TransactionManager
                        Dim bTrans As DatabaseServices.Transaction
                        Dim bDwg As Document
                        Dim bBT As BlockTable
                        Dim bBTR As SymbolTableRecord
                        Dim bBTE As SymbolTableEnumerator
                        Dim bBTRr As BlockTableRecord
                        bDwg = Application.DocumentManager.MdiActiveDocument
                        bTransMan = bDwg.TransactionManager
                        bTrans = bTransMan.StartTransaction
                        Try
                            bBT = bDwg.Database.BlockTableId.GetObject(OpenMode.ForRead)
                            bBTE = bBT.GetEnumerator
                            Dim XrefIds As New ObjectIdCollection
                            While bBTE.MoveNext = True
                                bBTR = bBTE.Current.GetObject(OpenMode.ForRead)
                                bBTRr = CType(bBTR, BlockTableRecord)
                                If bBTRr.IsFromExternalReference And bBTRr.IsResolved Then
                                    XrefIds.Add(bBTR.Id)
                            End While
                            Try
                                bDwg.Database.BindXrefs(XrefIds, False)
                            Catch ex As Exception
                                MsgBox("Error: " & ex.Message)
                            End Try
                             bTrans.Commit()
                            MsgBox(ex.Message, MsgBoxStyle.Critical)
                        Finally
                            bTrans.Dispose()
                            bTransMan.Dispose()
                        End Try
                        db.SaveAs(db.OriginalFileName, True, db.OriginalFileVersion, db.SecurityParameters)
                    End Using
                Next
 End Sub
</autodesk.autocad.runtime.commandmethod("bxb",>
Replies (15)
Message 2 of 16
_gile
I'm not very cumfortable with VB but this line hurts me:
If this is not the source of the error, could you say which line throws the "invalid input error" error.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 16
yoitsarun
error message is from here:
Try
bDwg.Database.BindXrefs(XrefIds, False) Catch ex As Exception MsgBox("Error: " & ex.Message) End Try
Message 4 of 16
yoitsarun
one more thing this code is working if i run individually (not as batch).
Message 5 of 16
_gile
To know the line the error occured, you can try replacing the Catch block with this:
Try
bDwg.Database.BindXrefs(XrefIds, False) Catch ex As Exception MsgBox("Error: " & ex.Message & vbCr & ex.StackTrace) End Try
Gilles Chanteau
GileCAD
GitHub
Message 6 of 16
yoitsarun
error is:
Message 7 of 16
_gile
The error is due to line 183 in the file BatchXrefBind.vb.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 16
yoitsarun
yes, but i dont know what is the error in this code
Message 9 of 16
_gile
The error is probably due the the contents of XrefIds.
Pay attention to what's said i the documentation for the BindXrefs method:
"The object IDs in xrefIds must all be from the database and they must all be resolved."
It seems to me bDwg is the active document (i.e. the document where the command was launched) and XrefIds contains objectIds from the opened in memory database.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 16
yoitsarun
something wrong in active document ?
I am new to this, but I did xref bind program in editor using same code and it works.
How it will work in memory database, if you know something please help me.
If you are in familiar in c# it is ok. I can convert.
Message 11 of 16
_gile
"The object IDs in xrefIds must all be from the database" i.e., the database you create 'in memory' (db).
Try:
db.BindXrefs(XrefIds, False)
Gilles Chanteau
GileCAD
GitHub
Message 12 of 16
yoitsarun
I tried this, but no luck, same "error: invalid input"
Message 13 of 16
_gile
Try like this (not tested)
using System.Windows.Forms;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using AcCoreAp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
namespace BindXrefsSample
    public class Commands
        [CommandMethod("TEST1")]
        public static void BindXrefsInCurrentDrawing()
            BindXrefs(HostApplicationServices.WorkingDatabase);
        [CommandMethod("TEST2")]
        public static void BindXrefsInDwgFiles()
            var ofd = new OpenFileDialog{
                InitialDirectory = "C:\\",
                Filter = "Drawing files|*.dwg",
                Multiselect = true};
            if (ofd.ShowDialog() == DialogResult.OK)
                foreach (string fileName in ofd.FileNames)
                    using (var db = new Database(false, true))
                        db.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, false, null);
                        BindXrefs(db);
                        db.SaveAs(fileName, true, db.OriginalFileVersion, db.SecurityParameters);
        private static void BindXrefs(Database db)
            try
                var xrefIds = new ObjectIdCollection();
                using (var tr = new OpenCloseTransaction())
                    var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    foreach (ObjectId id in bt)
                        var btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
                        if (btr.IsFromExternalReference && btr.IsResolved)
                            xrefIds.Add(id);
                db.BindXrefs(xrefIds, false);
            catch (System.Exception ex)
                AcCoreAp.ShowAlertDialog("Error: " + ex.Message);
Gilles Chanteau
GileCAD
GitHub
Message 14 of 16
_gile
This version of the BindXrefs() method resolves the xrefs in the database before binding them.
            var workingDb = HostApplicationServices.WorkingDatabase;
            HostApplicationServices.WorkingDatabase = db;
            try
                db.ResolveXrefs(true, false);
                            xrefIds.Add(id);
            finally
                HostApplicationServices.WorkingDatabase = workingDb;
Gilles Chanteau
GileCAD
GitHub
Message 15 of 16
yoitsarun
thanks a lot,
I will try this in the evening , and will update the results. thanks _gile
Message 16 of 16
yoitsarun
and it is working thanks gile
