Batch Convert Plot Styles Script (CTB to STB)
David_Prontnicki
David_Prontnicki
Does anyone know if its possible to use the command CONVERTPSTYLE in a script? And if so, does anyone have an example?
I am trying to convert a directory of drawings, and I have tried a few things but nothing is working.
I have tried the following, a .NET program calling to the AcCoreConsole to run a script that loads the lisp and run it. But it does not run. Note: The Lisp works if loaded and run from inside of AutoCAD.
I have used this same process to NETLOAD a .dll and it works great. But it is not working with a LiSP... and I also cant figure out how to convert in .NET.  (I can go from stb to ctb but not the other way. See below.)
I would love to simplify this by using script pro or a .bat but cant seem to figure out how to script the command CONVERTPSTYLE...
Here is the script:
(load "C:\\Program Files\\Batch Convert Plot Styles\\Support\\CEDBCPSCTL.lsp")
(command "CEDBCPSCTL")
Here is the LiSP:
(defun c:CEDBCPSCTL ()
(vl-load-com)
;;; This section will temporarily turn off the creation of .bak files!
(COMMAND "ISAVEBAK" "0")
;;; This section will convert PStyles to the Color Mapping STB!
(COMMAND "CONVERTPSTYLES" "Color Mapping.stb")
;;; This section will Pause the routine to allow additional time after color mapping!
(command "_.delay" 5000)
;;; This section will change the PlotStyle Table to the stb!
(vla-put-StyleSheet (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object))) "C3D.stb")
;;; This section will save the drawing!
(COMMAND "_.qsave")
(COMMAND "ISAVEBAK" "1")
;;; This section will close the drawing!
(COMMAND "_.close" "_Y")
Here is my .NET call:
Try
                For Each drawingfile In LstDrawings.Items
                    LblDrawingName.TextAll = "Processing: " & drawingfile.ToString
                    Dim workerThread As Thread = _autocadServices.RunAccoreconsoleApplication(My.Settings.AccoreConsoleApplicationPath,
        drawingfile, My.Settings.ScriptFilePath, 30000)
                    _autocadServices.ProcessDrawing(workerThread)
                    PrbConvert.Value += 1
                Next
                MessageServices.DisplayComplete("Conversion Complete!", "Execution of batch conversion is completed.")
            Catch ex As Exception
                MessageServices.DisplayError("Error Extracting Drawing Information!", "Please Contact the CADD Department.", ex)
                Refresh()
            End Try
I have used the following .NET in the past but it seems to only work when going from STB to CTB. I need to do the opposite...
Public Sub ConvertPlotStyles(ByVal acDocEd As Editor)
        Try
            acDocEd.Command("CONVERTPSTYLES")
            _variableServices.ResetSystemVariables()
            Dim frmMessageBox As New frmMessageBox
            frmMessageBox.lblHeader.Text = "Maser Consulting - Prep for ALCOSAN"
            frmMessageBox.lblMessageTitle.Text = "Error Converting Plotstyle!"
            frmMessageBox.lblMessageBody.Text = "Please ensure the drawing is not already a .ctb drawing file."
            frmMessageBox.picIcon.Image = My.Resources.msbError
            frmMessageBox.ShowDialog()
        End Try
    End Sub
    Public Sub AssignPlotStyle(ByVal acCurDb As Database, ByVal acTrans As Transaction)
        Try
            Dim layoutDbDictionary As DBDictionary = acTrans.GetObject(acCurDb.LayoutDictionaryId, OpenMode.ForRead)
                For Each layoutDbDictionaryEntry As DBDictionaryEntry In layoutDbDictionary
                    Dim layout As Layout = CType(layoutDbDictionaryEntry.Value.GetObject(OpenMode.ForWrite), Layout)
                    Dim plotSetVal As PlotSettingsValidator = PlotSettingsValidator.Current
                    plotSetVal.RefreshLists(layout)
                    plotSetVal.SetCurrentStyleSheet(layout, CTB_FILE_NAME)
                    layoutList.Add(layout)
                    layoutNameList.Add(layout.LayoutName.ToString)
                Next
            'Left Empty for puposes of posting...
        End Try
    End Sub
maratovich
Maybe this will help you - AutoRunLisp
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
David_Prontnicki
Thank you, this utility is great! (I just wish it could run in AcCoreConsole as an option, but defiantly not a deal breaker. )
Thank you again!
