Autoloading plugins with ACAD 2025
Andrew_Roe
Andrew_Roe
I've got a plugin that works fine in AutoCAD 2024 and earlier versions. In AutoCAD 2025, it does not load. I can get things to work by NETLOADing the DLLs and manually loading the menu using CUILOAD, but I'd like everything  to autoload.  I place the plugin in the following folder:
...\Program Files\Autodesk\ApplicationPlugins
... and this has worked fine in the past. Is there something I need to differently in 2025 to get it to work?
TIA
Andy
kerry_w_brown
Do you have SeriesMax and SeriesMin assigned values ??
https://adndevblog.typepad.com/autocad/2024/06/autocad-2025-update-your-packagecontentsxml-with-runt...
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Andrew_Roe
Adding a SeriesMax value fixed it. Thanks!
