Autocad mechanical - automatic Parts List extraction (C#)
Message 1 of 13
I am trying to access the Parts List created by Autocad Mechanical.
It can be done manually in Autocad Mechanical , but I'd like to automate it. Link to manually extract the parts list
I found this code in VBA, which I could convert to C#, but i do not have AtuoDesk McadAuto Type Library, even though I have Autocad Mechanical Installed. I have tried to find it, but have had no success.
I looked at the Developer Guide for AutoCAD Mechanical, but this did not seem to help
The code below finds the parts list in the attached drawing file, but i cannot find what to do to read the parts list.
DBObjectCollection objs = new DBObjectCollection();
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
ObjectId Id;
using (Transaction tr = db.TransactionManager.StartTransaction())
    BlockTable bt;
    bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
    BlockTableRecord btr;
    btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead) as BlockTableRecord;
    ObjectIdCollection ids = new ObjectIdCollection();
    foreach (ObjectId id in btr)
        if (id.ObjectClass.DxfName == "ACMPARTLIST")
            // code to read data from parts list
The ACMPARTLIST looks like a table, but it cannot be extracted using the autocad command TableExport, or DataExtraction.
I have tried other suggestions. This one extracts tables, but ACMPARTLIST is not a table.
http://forums.autodesk.com/t5/net/extracting-bom-from-autocad-using-c/m-p/3873852#M34623
Do i need the McadAuto.dll so I can access the BOM, or am i missing something else?
Replies (12)
Message 2 of 13
FRFR1426
You need to add a reference to MCadAuto and SymBBAuto library (they are in C:\Program Files\Common Files\Autodesk Shared), then you can access the parts list with code like this (not tested):
Set mcad = app.GetInterfaceObject("AcadmAuto.AcadmApplication")
Dim oSymBB As McadSymbolBBMgr = mcad.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr") Dim oBOMMgr As McadBOMMgr = oSymBB.BOMMgr If oBOMMgr.BOMTableExists("testBOM") Then Set oBOM As McadBOM = oBOMMgr.GetBOMTable(doc.ModelSpace, "testBOM")
// See documentation for McadBOM to see what you can do with that
// http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=14952981 End If
Please note that it is recommended to put the version in the ProgId (AcadmAuto.AcadmApplication.5 for AutoCAD 2016 for example)
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 3 of 13
Thanks for that, they were there all along with a slightly different name.
The link you gave did not work. I tried searching for something similar, but i cannot find how to read the parts list data of each item in the parts list.
Below is my current code.
It finds the BOM table (Always called MAIN).
I tried
                 SymBBAuto.IMcadSymbolBBMgr symbbmgr;
                    symbbmgr = acApp.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr");
                    SymBBAuto.IMcadBOMs cadBOMs;
                    cadBOMs = symbbmgr.BOMMgr.GetAllBOMTables(false);
                    SymBBAuto.IMcadBOM cadBOM;
                    cadBOM = cadBOMs.Item(0);
                    SymBBAuto.IMcadBOMMgr cadBOMmgr;
                    cadBOMmgr = symbbmgr.BOMMgr;
                    if (cadBOMmgr.BOMTableExists("MAIN"))
                        cadBOMmgr.ExportBOM(cadBOM, "csv", FullPatheName); // doesnt do anything
                        IMcadBOMItems bomItems = cadBOM.Items;
                        object oItem;
                        foreach (McadBOMItem bomItem in bomItems)
                            // add code to read parts list data
I tried to export the BOM, which did not work.
I also tried to export the parts list from the BOM, which gave me the error "the file being exported to cannot be created"
                        McadBOMMgr cadBOMmgr2;
                        cadBOMmgr2 = symbbmgr.BOMMgr as McadBOMMgr;
                        McadPartLists PL;
                        PL = cadBOM.PartLists;
                        cadBOMmgr2.ExportPartList(McadBOMExportFormatType.exCSV, PL.Item(0), FullPathName, "MAIN", true);
I tried to go through each bom item and extract its data, but i could notfind how to get this data
                        object oItem;
                            // add code to get item of each bom item
If you have any advice/links on how to get any of them to work, that would be greatly appreciated.
Thank you.
Message 4 of 13
FRFR1426
FileType should be .csv (starting with a dot).
cadBOMmgr.ExportBOM(cadBOM, ".csv", FullPatheName);
Maxence DELANNOY
Manager
http://wiip.fr
Message 5 of 13
I added the starting dot, but it does not create any file.
This is the path i chose (just a temp path for testing). I also tried it without the .csv in FullPAtheName and that didnt work either.
Would anything in this stop it working?
string FullPatheName = @"C:\BOM Out.csv";
Do you have any links to other examples?
I have searhed through alot of other posts but cannot find any.
Message 6 of 13
I still cannot get this to work, this is my code
        public static void Extract_BOM()
            string FullPathName = @"C:\BOM Out.csv";
            string BomName = "MAIN";
                AcadApplication acApp = null;
                const string progID = "AutoCAD.Application.19";
                acApp = (AcadApplication)Marshal.GetActiveObject(progID);
                if (acApp != null)
                    AXDBLib.AcadObject obj;   //requires AXDBlib reference
                    LayoutManager LM = LayoutManager.Current;
                    try
                        obj = (AXDBLib.AcadObject)LM.GetLayoutId(LM.CurrentLayout).GetObject(OpenMode.ForRead).AcadObject;
                        //  sheetSetMgr.GetSheetFromLayout(obj, out sheet);
                        if (cadBOMmgr.BOMTableExists(BomName))
                            cadBOMmgr.ExportBOM(cadBOM, ".csv", FullPathName);
                        catch (System.Exception e)
                            System.Windows.Forms.MessageBox.Show("There was an error getting the sheet set info for this layout: " + e.Message);
The line
Gives me the error "There was an error getting the sheet set info for this layout: Error HRESULT E_FAIL has been returned from a call to a COM component.
I have tried a few methods as previously stated.
Do you have any links where I can view working code, so I can work backwards from it?
Message 7 of 13
Try the direct interface to AcadApplication instead of using Marshal.
AcadApplication acApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
AcadDocument acDoc = acApp.ActiveDocument
I found this works better in .net than using the COM interface.
EDIT:
You may also need to add
Using Autodesk.AutoCAD.Interop;
Using Autodesk.AutoCAD.Interop.Common;
Message 8 of 13
Okay, I got it working in VB.net. First thing to note is the COM library has Interface and Non-Interface variables. Once you have an Interface variable you want to save it to a non-Interface type variable and then dispose of the interface.
I found that using SymBBAuto.IMcadBOM would throw an error about not being able to write while SymBBAuto.McadBOM wrote the file.
Dim FullPathName As String = "c:\test\test.csv"
Dim BomName As String = "MAIN"
Dim acadApp As AcadApplication = Application.AcadApplication
Dim acadDoc As AcadDocument = acadApp.ActiveDocument
' Get the Surface Texture Library Object
Try
	' Get Interface to SymbolBBMMgr
	Dim I_symBBmgr3 As IMcadSymbolBBMgr3 = Nothing
	I_symBBmgr3 = acadDoc.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
	' Get Interface to BOMMgr from the active document
	Dim I_cadBOMmgr3 As SymBBAuto.IMcadBOMMgr3 = Nothing
	I_cadBOMmgr3 = I_symBBmgr3.BOMMgr(acadDoc)
	' Save the Contents to Non-Interface variable
	Dim cadBOMmgr As SymBBAuto.McadBOMMgr = Nothing
	cadBOMmgr = I_cadBOMmgr3
	' Dispose of the Interface
	I_cadBOMmgr3 = Nothing
	' Check if BOMName exists in Table
	If cadBOMmgr.BOMTableExists(BomName) Then
		' Get the BOMTable by name (Non-Interface Variable)
		Dim cadBom As SymBBAuto.McadBOM = Nothing
		cadBom = cadBOMmgr.GetBOMTableByName(BomName)
		If cadBom IsNot Nothing Then
			cadBOMmgr.ExportBOM2(SymBBAuto.McadBOMExportFormatType.exCSV, cadBom, FullPathName, "Main", True)
Catch acEx As Autodesk.AutoCAD.Runtime.Exception
	' Write Error Message
Catch ex As System.Exception
End Try
This should be fairly easy to translate to C# if that is what you need. If you are going from VBA, I would suggest VB.net instead of C#.net because it's a little less of a learning curve. However, most people do use C# so it's all up to you on which one to use.
Hope this helps!
Message 9 of 13
Here is the c# version:
string FullPathName = "c:\\test\\test.csv";
AcadApplication acadApp = Application.AcadApplication;
AcadDocument acadDoc = acadApp.ActiveDocument;
// Get the Surface Texture Library Object
try
    // Get Interface to SymbolBBMMgr
    IMcadSymbolBBMgr3 I_symBBmgr3 = null;
    I_symBBmgr3 = acadDoc.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr");
    // Get Interface to BOMMgr from the active document
    SymBBAuto.IMcadBOMMgr3 I_cadBOMmgr3 = null;
    I_cadBOMmgr3 = I_symBBmgr3.BOMMgr(acadDoc);
    // Save the Contents to Non-Interface variable
    SymBBAuto.McadBOMMgr cadBOMmgr = null;
    cadBOMmgr = I_cadBOMmgr3;
    // Dispose of the Interface
    // Check if BOMName exists in Table
        // Get the BOMTable by name (Non-Interface Variable)
        SymBBAuto.McadBOM cadBom = null;
        cadBom = cadBOMmgr.GetBOMTableByName(BomName);
        if (cadBom != null)
            cadBOMmgr.ExportBOM2(SymBBAuto.McadBOMExportFormatType.exCSV, cadBom, FullPathName, "Main", true);
catch (Autodesk.AutoCAD.Runtime.Exception acEx)
    // Write Error Message
catch (System.Exception ex)
Message 10 of 13
Did the C# code compile for you?
I received the following errors;
I tried to fix it, but couldn't get it to work.
Error CS1955 Non-invocable member 'IMcadSymbolBBMgr3.BOMMgr[object]' cannot be used like a method.
Error CS0266 Cannot implicitly convert type 'SymBBAuto.IMcadBOMMgr3' to 'SymBBAuto.McadBOMMgr'. An explicit conversion exists (are you missing a cast?)
Error CS0266 Cannot implicitly convert type 'SymBBAuto.IMcadBOM' to 'SymBBAuto.McadBOM'. An explicit conversion exists (are you missing a cast?)
Error CS0266 Cannot implicitly convert type 'object' to 'Autodesk.AutoCAD.Interop.AcadApplication'. An explicit conversion exists (are you missing a cast?)
Thanks in advance.
Message 11 of 13
Unfortunately I hadn't tested the C# code. All my development in Autocad has been with VB. All my C# experience comes from my development with CATIA which has mostly been at the COM level. Try these fixes, they should help a bit.
The VB intellisense shows that it's needed but the Object Browser shows the param as optional. Try removing the acadDoc from the line.
I_cadBOMmgr3 = I_symBBmgr3.BOMMgr;
 This line also has another error with the solution below.
These should be able to be fixable by explicitly casting; something like this:
I_symBBmgr3 = (IMcadSymbolBBMgr3)acadDoc.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr");
I_cadBOMmgr3 = (SymBBAuto.IMcadBOMMgr3)I_symBBmgr3.BOMMgr;
cadBOMmgr = (SymBBAuto.McadBOMMgr)I_cadBOMmgr3;
That will explicitly cast the objects and should hopefully fix them.
Let me know how it goes.
Message 12 of 13
Scratch some of that previous post, the first error wasn't happening in the spot I thought it was. Compiled, and tested C# code is as follows.
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using SymBBAuto;
using Autodesk.AutoCAD.Interop;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(TESTER.MyCommands))]
namespace TESTER
    public class MyCommands
        // Modal Command with localized name
        [CommandMethod("TTT", "TTT", CommandFlags.Modal)]
        public void TTT() // This method can have any name
            string FullPathName = "c:\\temp\\test.csv";
            AcadApplication acadApp = (AcadApplication)Application.AcadApplication;
            try
                    cadBom = (SymBBAuto.McadBOM)cadBOMmgr.GetBOMTableByName(BomName);
                    if (cadBom != null)
Do note the output directory "FullPathName" must be an actual location. The export doesn't seem to want to create folders. The file it creates okay, however.
Cheers.
Message 13 of 13
I see where i went wrong.
Makes sense, and worked perfectly.
Thanks a lot for the help.
