.NET
AutoCAD is not responsive after closing customized dialog.
4 REPLIES 4
MarkJamesRogolino
212 Views, 4 Replies
Hello, everyone.
I have a small autocad plugin including license checking dialog.
I wanna make to request license key so it shows customized modal dialog before some commands work.
but after license key dialog exit AutoCAD does not work and not responsive.
my codes are followings.
IntPtr acadHandle = Application.MainWindow.Handle;
using(LicenseForm licfrm = new LicenseForm())
NativeWindow nativeWindow = new NativeWindow();
nativeWindow.AssignHandle(acadHandle);
licfrm.ShowDialog(nativeWindow);
nativeWindow.ReleaseHandle();
return;
How to solve it?  I am enclosing working video.
4 REPLIES 4
Firstly, you should not call Show()/ShowDialog() from you LicenseForm (be it WinForm, or WPF dialog box). Instead, call:
Application.ShowModal[Modeless]Dialog[Winodw]() method.
Secondly, you did not say/show anything about NativeWindow class, but I suspect it is the cause of the hanging,
Anyway, if you use Application.ShowModalDialog(), your UI (LicenseForm) would automatically owned by AutoCAD's main window inexplicitly, or you can pass the main window's handle to explicitly make the main window as the dialogbox's owner. Whichever overloaded method you call, you would not have the "hanging" issue.
Norman Yuan
Drive CAD With Code
NativeWindow is just a wrapper for a window handle, and shouldn't be needed for what you're doing. You should follow @norman.yuan's advice for showing a modal dialog.
_gile
in reply to: MarkJamesRogolino
You may find inspiration in these examples of AutoCAD user interfaces.
Gilles Chanteau
GileCAD
GitHub
MarkJamesRogolino
in reply to: _gile
Thank you, _gile
Tags (1)
AutoCAD Inside the Factory
