I have been writing a program that imports points from a selected file. I know about importing points from insert tab on the ribbon, but I want this to run after some other code that I have. Every time I run this code, I get the error that no points were transferred from file. I have attached the file I am pulling for reference. I am at a complete loss and have been working on this for a few days now. Any help would be appreciated! Thanks!
Imports Autodesk.Civil.ApplicationServices
Imports Autodesk.Civil.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Public Class Class1
Public Shared Sub importPointsFromFile()
Dim acDoc As Document = Core.Application.DocumentManager.MdiActiveDocument
Dim civilDoc As CivilDocument = CivilApplication.ActiveDocument
Dim acCurDb As Database = acDoc.Database
Using trans As Transaction = acCurDb.TransactionManager.StartTransaction()
Dim pointFileName As String = "C:\Users\jdalton\Desktop\091021_PCV3_ASB_SH.csv"
Dim pointFileFormatName As String = "PNEZD (comma delimited)"
Dim pointFileFormat As PointFileFormat = PointFileFormatCollection.GetPointFileFormats(acCurDb).Item(pointFileFormatName)
Dim pointGroupId As ObjectId = civilDoc.PointGroups.Add("-FIELD IMPORT")
Dim result As UInteger = CogoPointCollection.ImportPoints(pointFileName, pointFileFormat, False, False, False, pointGroupId)
trans.Commit()
End Using
End Sub
End Class
Also I am using AutoCAD Civil3D 2022 and 4.7.2 Net Framework
Edit: I have also tried having a Cogo Point in the blank drawing to see if that would do anything. I also attached the error picture.
Edit 2: I get an error also adding the point group on line 15 and another error when adding the points (with and without the inclusion of pointgroupId)
