AutoCAD 2018 ,NET Wizard for Visual Studio 2017
Where do I find AutoCAD 2018 ,NET Wizard for Visual Studio 2017 ?
One for VS 2015 does not work with VS 2017
Alexander.Rivilis
"There is not AutoCAD .NET Wizard for VS 2017"
This answer was done to me some monthes ago by ADN DevHelp.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
kerry_w_brown
You may glean something from these posts :
Topic: Visual Studio Project Template
https://www.theswamp.org/index.php?topic=53118.0
or
Topic: Using ContextMenuExtension for testing from Visual Studio.
https://www.theswamp.org/index.php?topic=53143.0
or (old)
Topic: AutoStart Netload when debugging.
https://www.theswamp.org/index.php?topic=14492.0
or several posts here and elsewhere by Gilles regarding Templates.
My experience has been "it's better to learn to build your own"
added:
Sorry Alexander, this was in reply to sanpo not you 🙂
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
_gile
I think build your own templates is a good way to start learning .NET.
To build a Visual Studio template, just start an AutoCAD project from scratch and export the template.
But you can add some interesting features to you template like automating NETLOAD of your project when debugging.
I wrote a tutorial about creating a Visual Studio template for an AutoCAD C# project:
original French version
English (automatic) translation
You can also get some already made templates from this page.
Gilles Chanteau
GileCAD
GitHub
