AutoCAD 2016 Multipage plot crashing at BeginGenerateGraphics()
Message 1 of 13
I have used below function to create Multipage PDF of all layouts of dwg file. But AutoCAD 2016 crashes when for-loop execute for second layout at BeginGenerateGraphics() line. Same code works perfectly in AutoCAD 2013
My machine configuration is Windows 7 SP1 64 bit, AutoCAD 2016 64 bit .NET framework 4.5
Please help.
[CommandMethod("mplot")]
static public void MultiSheetPlot()
Document doc =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
Transaction tr =
db.TransactionManager.StartTransaction();
using (tr)
BlockTable bt =
(BlockTable)tr.GetObject(
db.BlockTableId,
OpenMode.ForRead
// A PlotEngine does the actual plotting
// (can also create one for Preview)
if (PlotFactory.ProcessPlotState ==
ProcessPlotState.NotPlotting)
PlotEngine pe =
PlotFactory.CreatePublishEngine();
using (pe)
// Create a Progress Dialog to provide info
// and allow thej user to cancel
ObjectIdCollection layoutsToPlot =
new ObjectIdCollection();
foreach (ObjectId btrId in bt)
BlockTableRecord btr =
(BlockTableRecord)tr.GetObject(
btrId,
OpenMode.ForRead
if (btr.IsLayout &&
btr.Name.ToUpper() !=
BlockTableRecord.ModelSpace.ToUpper())
layoutsToPlot.Add(btrId);
PlotProgressDialog ppd =
new PlotProgressDialog(false, layoutsToPlot.Count, true);
using (ppd)
int numSheet = 1;
foreach (ObjectId btrId in layoutsToPlot)
PlotInfoValidator piv = new PlotInfoValidator();
piv.MediaMatchingPolicy =
MatchingPolicy.MatchEnabled;
btrId,
OpenMode.ForRead
Layout lo =
(Layout)tr.GetObject(
btr.LayoutId,
OpenMode.ForRead
PlotInfo pi = new PlotInfo() { Layout = lo.ObjectId }; ;
// We need a PlotSettings object
// based on the layout settings
// which we then customize
LayoutManager.Current.CurrentLayout = lo.LayoutName;
PlotSettings ps =
new PlotSettings(lo.ModelType);
ps.CopyFrom(lo);
// The PlotSettingsValidator helps
// create a valid PlotSettings object
PlotSettingsValidator psv =
PlotSettingsValidator.Current;
// We'll plot the extents, centered and
// scaled to fit
psv.SetPlotType(
ps,
Autodesk.AutoCAD.DatabaseServices.PlotType.Extents
psv.SetUseStandardScale(ps, true);
psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
psv.SetPlotCentered(ps, true);
// We'll use the standard DWFx PC3, as
// this supports multiple sheets
psv.SetPlotConfigurationName(
ps,
//"DWFx ePlot (XPS Compatible).pc3",
"DWG To PDF.pc3",
"ANSI_A_(8.50_x_11.00_Inches)"
// We need a PlotInfo object
// linked to the layout
pi.Layout = btr.LayoutId;
// Make the layout we're plotting current
lo.LayoutName;
LayoutManager.Current.SetCurrentLayoutId(btr.LayoutId);
// We need to link the PlotInfo to the
// PlotSettings and then validate it
pi.OverrideSettings = ps;
piv.Validate(pi);
if (numSheet == 1)
ppd.set_PlotMsgString(
PlotMessageIndex.DialogTitle,
"Custom Plot Progress"
PlotMessageIndex.CancelJobButtonMessage,
"Cancel Job"
PlotMessageIndex.CancelSheetButtonMessage,
"Cancel Sheet"
PlotMessageIndex.SheetSetProgressCaption,
"Sheet Set Progress"
PlotMessageIndex.SheetProgressCaption,
"Sheet Progress"
ppd.LowerPlotProgressRange = 0;
ppd.UpperPlotProgressRange = 100;
ppd.PlotProgressPos = 0;
// Let's start the plot, at last
ppd.OnBeginPlot();
ppd.IsVisible = true;
pe.BeginPlot(ppd, null);
// We'll be plotting a single document
pe.BeginDocument(
pi,
doc.Name,
null,
1,
true, // Let's plot to file
"E:\\test-multi-sheet"
// Which may contain multiple sheets
ppd.StatusMsgString =
"Plotting " +
doc.Name.Substring(
doc.Name.LastIndexOf("\\") + 1
" - sheet " + numSheet.ToString() +
" of " + layoutsToPlot.Count.ToString();
ppd.OnBeginSheet();
ppd.LowerSheetProgressRange = 0;
ppd.UpperSheetProgressRange = 100;
ppd.SheetProgressPos = 0;
PlotPageInfo ppi = new PlotPageInfo();
pe.BeginPage(
ppi,
pi,
(numSheet == layoutsToPlot.Count),
null
pe.BeginGenerateGraphics(null);
ppd.SheetProgressPos = 50;
pe.EndGenerateGraphics(null);
// Finish the sheet
pe.EndPage(null);
ppd.SheetProgressPos = 100;
ppd.OnEndSheet();
bool ok = pe.IsDisposed;
numSheet++;
// Finish the document
pe.EndDocument(null);
// And finish the plot
ppd.PlotProgressPos = 100;
ppd.OnEndPlot();
pe.EndPlot(null);
pe.Dispose();
else
ed.WriteMessage(
"\nAnother plot is in progress."
Replies (12)
Message 2 of 13
FRFR1426
Not sure it's the root of your problem, but you are calling pe.Dispose() twice. You use an using and you call explicitly dispose.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 3 of 13
Hello Maxene,
Thanks for the reply. The same code works perfectly in AutoCAD 2013 64 bit (Windows 7 SP1) but if I use AutoCAD 2016 64 bit (Windows 7 SP1) it crashes. Please see attached image of Fatal Error.
Please help.
Pushpka
Message 4 of 13
FRFR1426
May be you are plotting in the background in 2016. Try to put this line at the top to plot in the foreground:
Application.SetSystemVariable("BACKGROUNDPLOT", 0);
Maxence DELANNOY
Manager
http://wiip.fr
Message 5 of 13
Hello Maxence,
I have added this line at top but still same result.. AutoCAD crash.
Surprisingly it works perfectly AutoCAD 2013.
Please help.. I am really fed up now...
Message 6 of 13
FRFR1426
There is nothing surprising in that. You know, code changes between releases... I'm afraid I cannot help you more, I've run out of ideas and I cannot spend more time on this issue, sorry.
Maxence DELANNOY
Manager
http://wiip.fr
Message 7 of 13
Please see attached image from the forum http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-multi.html
Someone reports the same problem but Kean Walmsley mentioned that he could not observe the issue.
Can you please help on it further.
Thanks in advance
Message 8 of 13
I tried same above code in the Autodesk 2016 (64 bit) Windows 7 SP1 Microsoft Visual Studio 2015 (same install as my machine), it works without crash.
What could be the reason?
Thanks in advance.
Message 9 of 13
FRFR1426
Sometimes, programs can behave differently when there is a debugger attached.
Maxence DELANNOY
Manager
http://wiip.fr
Message 10 of 13
I tried with debugger but same code works. Don't know the reason.
Message 11 of 13
Did you find the answer? I have the same problem.
Message 12 of 13
John204
We had the same problem with the BeginGenerateGraphics method and found that the problem is with Service Pack 1 for AutoCAD 2016.  When we uninstalled SP1 for AutoCAD 2016 our program worked fine.  We were wondering if anyone knows if this is fixed in AutoCAD 2018 or 2019 since we are considering an upgrade soon?
Message 13 of 13
lifanvc
hi , I have the game question, how to do ? can you help me ?
