AttributeReference TextString problem
I need to obtain the value of an AttributeReference in a BlockReference, I've done everything necessary to obtain the AttributeReference without problem, but when I access the TextString property it returns "" (Empty), I know for sure the drawing has value assigned in the block.
Any help is appreciated, thanks
Eric
There's not much anyone can do without seeing your code.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:5944798@discussion.autodesk.com...
Eric
I don't know why but with some new drawings, done with full AutoCAD, I can successfully read the attributes values, but with other drawings which have been modified and saved with AutoCAD LT I can't.
Eric
Got a sample?
wrote in message news:5947497@discussion.autodesk.com...
Eric
Hi Tony,
This is the code I'm using:
[CommandMethod("tar")]
public void TestAttributeReference()
Database db = HostApplicationServices.WorkingDatabase;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
using (Transaction trans = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForWrite);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt["INFO_HOJAS_ATT"], OpenMode.ForRead);
foreach (ObjectId oid in btr.GetBlockReferenceIds(true, false))
BlockReference titleBlock = trans.GetObject(oid, OpenMode.ForRead) as BlockReference;
if (titleBlock == null) continue;
foreach (ObjectId attOid in titleBlock.AttributeCollection) {
AttributeReference ar = (AttributeReference)trans.GetObject(attOid, OpenMode.ForWrite);
ed.WriteMessage(String.Format("{0} = {1}\n", ar.Tag, ar.TextString));
// trans.Commit();
And attached id one of the files without xrefs. But now is working fine I'm using a different PC from the original test. Will check tomorrow from the office.
Eric
