Attribute to excel with count
CAD-Geek
Message 1 of 8
CAD-Geek
After searching in forum I found code that extracts data from attribute block
but I need to modify the excel output result as DATAEXTRACTION command
            List<object[]> rooms = new List<object[]>();
            using (var tr = db.TransactionManager.StartTransaction())
                foreach (SelectedObject so in psr.Value)
                    BlockReference bref = (BlockReference)tr.GetObject(so.ObjectId, OpenMode.ForRead);
                    //populate array with attribute data
                    Autodesk.AutoCAD.DatabaseServices.AttributeCollection attcoll = bref.AttributeCollection;
                    object[] info = new object[4];
                    foreach (ObjectId id in attcoll)
                        AttributeReference atref = (AttributeReference)tr.GetObject(id, OpenMode.ForRead);
                        if (atref.Tag=="QUANTITY")
                            info[0] = atref.TextString;
                        if (atref.Tag=="MATERIAL")
                            info[1] = atref.TextString;
                        if (atref.Tag=="STANDARD")
                            info[2] = atref.TextString;
                        if (!rooms.Contains(info))
                            rooms.Add(info);
                tr.Commit();
the excel output
I need the result to be something like this
Replies (7)
Message 2 of 8
SENL1362
search for GROUP BY
Message 3 of 8
_gile
You can have a look at this:
http://www.theswamp.org/index.php?topic=31859.msg452527#msg452527
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
CAD-Geek
thnx @_gile for reply I tried your code but I got this exception
Message 5 of 8
CAD-Geek
thnx @SENL1362 for the reply I tried your suggest like this
                            info[3] = rooms.GroupBy(x=>x).Count() + "c";
                            rooms.Add(info);
Message 6 of 8
SENL1362
For this:
Do this:
                //var info = new object[4];
                var rooms = new List<object[]>();
                rooms.Add(new object[] { 3, "", "MS02" });
                rooms.Add(new object[] { 1, "", "MS19E" });
                rooms.Add(new object[] { 3, "", "MS17B" });
                rooms.Add(new object[] { "1m", "439C", "" });
                rooms.Add(new object[] { 1, "", "MS47G" });
                rooms.Add(new object[] { "5m", "439C", "" });
                rooms.Add(new object[] { "5m", "430D", "" });
                var groupedRooms = rooms.GroupBy(x => new { A = x[1], B = x[2], C = x[0] }).Select(g => new { Count = g.Count(), Quantity = g.Key.C, Material = g.Key.A, Standard = g.Key.B });
                ed.WriteMessage("\nCount, 2-Quantity, 3-Material, 4-Standard");
                //foreach (var r in groupedRooms.OrderBy(n=>n.Count).ThenBy(m=>m.Material))
                foreach (var gr in groupedRooms)
                    ed.WriteMessage($"\n{gr.Count,5}, {gr.Quantity,-10}, {gr.Material,-10}, {gr.Standard,-10}");
Message 7 of 8
CAD-Geek
I tried
                            rooms.Add(new object[] { atref.TextString });
                            //info[0] = atref.TextString;
                            //info[1] = atref.TextString;
                            //info[2] = atref.TextString;
and I use this code to export to excel @Hallex
ExcelTool.FillExistingBook(@"C:\Test\Programming\BCOUNT.xlsx", new object[] { "Count","QUANTITY", "MATERIAL", "Standard" },  excdata);
but I got the error
Index was outside the bounds of the array
Message 8 of 8
_gile
As you have a tag named "QUANTITY"  you should change the "Quantity" column name of the DataTable.
Try replacing:
dTable.Columns.Add("Quantity", typeof(int));
with:
dTable.Columns.Add("Count", typeof(int));
or whatever else different from any attribute Tag.
Gilles Chanteau
GileCAD
GitHub
