Any way to get points used in GetSelection?
deltacadd
deltacadd
Is there any way to retrieve the list of points used for selecting objects when the Editor.GetSelection() method is run?
What I want is something like this:
Command: MyCommand
Select objects: WP
First polygon point: <Point picked>
Specify endpoint of line or [Undo]: <Point picked>
Specify endpoint of line or [Undo]: <ENTER>
The list of points is: <x,y>,<x,y>,<x,y>,<x,y>
Any help is much appreciated.
deltacadd
Never mind, I figured it out myself. Here is the code:
  class CommandShowPoints
    Point3dCollection m_pts = new Point3dCollection();
    public CommandShowPoints()
      Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
      PromptSelectionOptions pso = new PromptSelectionOptions();
      ed.PointMonitor += ed_PointMonitor;
      PromptSelectionResult psr = ed.GetSelection();
      ed.PointMonitor -= ed_PointMonitor;
      if (psr.Status == PromptStatus.Cancel) return;
ed.WriteMessage("\nList of picked points\n"); foreach (Point3d pt in m_pts) { ed.WriteMessage(string.Format("\n{0}", pt)); } } void ed_PointMonitor(object sender, PointMonitorEventArgs e) { Point3d ptLast = e.Context.LastPoint;
if ((ptLast != Point3d.Origin) && (m_pts.Contains(e.Context.LastPoint) == false))
m_pts.Add(e.Context.LastPoint);
Now, is there any way to know if the user select a "Window", "Crossing", "WindowPolygon" etc for the selection? I am not interested in querying the entities that are in the selection set, using the "SelectedObject.SelectionMethod", since the window /  crossing / whatever, may not result in a SelectionSet at all.
SENL1362
The following sample evaluate the Selection details, inclusive the Picked Points. No need for Point monitor
        [CommandMethod("TestSelection")]
        public static void TestSelection()
            Document doc = null;
            Database db = null;
            Editor ed = null;
            try
                doc = AcadApp.DocumentManager.MdiActiveDocument;
                if (doc == null)
                    throw new System.Exception("\n Drawing Document required");
                db = doc.Database;
                ed = doc.Editor;
                //Select Objects, use ed.GetSelection to benefit from Window/Crossing selection visual feedback
                pso.MessageForAdding = "Select  Objects";
                pso.SingleOnly = false;
                PromptSelectionResult psr = ed.GetSelection(pso);
                if (psr.Status != PromptStatus.OK)
                    return;
                SelectionSetDelayMarshalled ssMarshal = (SelectionSetDelayMarshalled)psr.Value;
                AdsName name = ssMarshal.Name;
                var selObjIds = ssMarshal.GetObjectIds();
                ed.WriteMessage("\n {0} Objects selected", selObjIds.Length);
                for (int i = 0; i < selObjIds.Length; i++)
                    ed.WriteMessage("\n\t [{0}]: {1} ({2})", i, selObjIds[i].ObjectClass.DxfName, selObjIds[i].Handle);
                SelectionSet selSet = (SelectionSet)ssMarshal;
                ed.WriteMessage("\n {0} Selections in SelectionSet", selSet.Count);
                foreach (SelectedObject ssItem in selSet)
                    ed.WriteMessage("\n\t {0} Selected: {1} ({2})", Enum.GetName(typeof(SelectionMethod), ssItem.SelectionMethod), ssItem.ObjectId.ObjectClass.DxfName, ssItem.ObjectId.Handle);
                    switch (ssItem.SelectionMethod)
                        case SelectionMethod.PickPoint:
                            PickPointSelectedObject ppSelObj = ssItem as PickPointSelectedObject;
                            Point3d pickedPoint = ppSelObj.PickPoint.PointOnLine;
                            ed.WriteMessage("\n\t\t Selected at: {0}", pickedPoint.ToString());
                            break;
                        case SelectionMethod.Crossing:
                            CrossingOrWindowSelectedObject crossSelObj = ssItem as CrossingOrWindowSelectedObject;
                            PickPointDescriptor[] crossSelPickedPoints = crossSelObj.GetPickPoints();
                            ed.WriteMessage("\n\t\t Crossing at: {0}..{1}", crossSelPickedPoints[0].PointOnLine.ToString(), crossSelPickedPoints[1].PointOnLine.ToString());
                            break;
                        case SelectionMethod.Window:
                            CrossingOrWindowSelectedObject windSelObj = ssItem as CrossingOrWindowSelectedObject;
                            PickPointDescriptor[] winSelPickedPoints = windSelObj.GetPickPoints();
                            ed.WriteMessage("\n\t\t Window at: {0}..{1}", winSelPickedPoints[0].PointOnLine.ToString(), winSelPickedPoints[1].PointOnLine.ToString());
                            break;
            catch (System.Exception ex)
                if (ed != null)
                    ed.WriteMessage(ex.Message);
                else
                    System.Windows.Forms.MessageBox.Show(ex.Message,
                                "TestSelection",
                                System.Windows.Forms.MessageBoxButtons.OK,
                                System.Windows.Forms.MessageBoxIcon.Error);
deltacadd
Not sure why, but running the above code shows the last two points for all the entities, if I have selected say a Window Polygon. See example below:
Output:
Command: tss
Select  Objects: wp
12 found
Select  Objects:
 12 Objects selected
 12 Selections in SelectionSet
Window at:
(1886.16856979758,755.163512841775,0)..(1888.90531905888,952.047645899205,0)
Window at:
Window at:
Window at:
Window at:
Window at:
Window at:
Window at:
Window at:
Window at:
Window at:
Window at:
Except for commenting the additional WriteMessages, no other change to the code you have supplied. Any idea why this is happening?
SENL1362
The sample assumed rectangular window (or crossing) selections only. For polygone selections use this slightly modified code.
PickPointDescriptor[] crossSelPickedPoints = crossSelObj.GetPickPoints(); if (crossSelPickedPoints != null) { for (int i = 0; i < crossSelPickedPoints.Length;i++ ) ed.WriteMessage("\n\t\t Crossing at[{0}]: {1}", i,crossSelPickedPoints[i].PointOnLine.ToString()); } } break; case SelectionMethod.Window: CrossingOrWindowSelectedObject windSelObj = ssItem as CrossingOrWindowSelectedObject; PickPointDescriptor[] winSelPickedPoints = windSelObj.GetPickPoints(); if (winSelPickedPoints != null) { for (int i = 0; i < winSelPickedPoints.Length; i++) ed.WriteMessage("\n\t\t Window at[{0}]: {1}", i, winSelPickedPoints[i].PointOnLine.ToString()); } break;
