Message 1 of 12
AddHandler CommandWillStart/RemoveHandler CommandWillStart not working
In my form I have a "OFF" button which fire's off the "RemoveHandler" part. Even after triggering the "RemoveHandler" the program is still issuing the "CommandWillStart" event. Here's my (fairly simple) problematic code I had written so far. I've chopped down most of the code that does not relate to the eventhandler. Is there any inconsistency concerning the "RemoveHandler" function?
You're help is much appreciated... Thanks!
Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.ApplicationServices.Core.Application Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.ApplicationServices.Application Imports System.Windows.Forms Imports Autodesk.AutoCAD.Colors Imports System.IO Imports Autodesk.AutoCAD.Runtime Public Class Form1 Implements IExtensionApplication Private CurrentLayerName As String Private _SelectedLayer As LayerData Private Shared acDoc As Document Public Sub Initialize() Implements IExtensionApplication.Initialize Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Initialize") acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument End Sub Public Sub Terminate() Implements IExtensionApplication.Terminate End Sub Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load _SelectedLayer = New LayerData End Sub Private Sub myOnButton_Click(ByVal sender As Object, ByVal e As EventArgs) Handles myOnButton.Click AddHandler acDoc.CommandWillStart, AddressOf SwapTheLayer End Sub Private Sub OFF_Button_Click(ByVal sender As Object, ByVal e As EventArgs) Handles OFF_Button.Click RemoveHandler acDoc.CommandWillStart, AddressOf SwapTheLayer End Sub Private Sub SwapTheLayer(ByVal senderObj As Object, ByVal e As CommandEventArgs) CurrentLayerName = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("CLAYER") Dim importedLayer As Array = _SelectedLayer.ToArray Select Case e.GlobalCommandName Case "MTEXT" If checkIfLayerExistInDrawing(MText_TextBox.Text) = True Then Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("layer exist") Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("CLAYER", MText_TextBox.Text.ToString) Else Dim myCreateLay As New CreateLayer(importedLayer(0).MyLayerName, importedLayer(0).MyLayerDescription, importedLayer(0).MyLayerColor, importedLayer(0).MyLayerPlot, importedLayer(0).MyLayerLinetypeName, importedLayer(0).MyLayerLineweight) Autodesk.AutoCAD.ApplicationServices.Core.Application.SetSystemVariable("CLAYER", MText_TextBox.Text) Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("layer do not exist in drawing") End If Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("AddHandler CommandEnded") AddHandler acDoc.CommandEnded, AddressOf BackToOriginalLayer AddHandler acDoc.CommandCancelled, AddressOf BackToOriginalLayer AddHandler acDoc.CommandFailed, AddressOf BackToOriginalLayer End Select End Sub Private Sub BackToOriginalLayer(ByVal senderObj As Object, ByVal e As CommandEventArgs) Select Case e.GlobalCommandName Case Is = "MTEXT" Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("CLAYER", CurrentLayerName) Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("RemoveHandler CommandEnded") RemoveHandler acDoc.CommandEnded, AddressOf BackToOriginalLayer RemoveHandler acDoc.CommandCancelled, AddressOf BackToOriginalLayer RemoveHandler acDoc.CommandFailed, AddressOf BackToOriginalLayer End Select End Sub Private Function checkIfLayerExistInDrawing(ByVal myLayerName As String) Dim LayerExist As Boolean '' Get the current document and database Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Layer table for read Dim acLyrTbl As LayerTable acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead) 'layer exist in drawing... If acLyrTbl.Has(myLayerName) = False Then LayerExist = False Else LayerExist = True End If End Using Return LayerExist End Function End Class
