Add custom properties to the object properties palette
eduardo_salvador02
eduardo_salvador02
Hello, I would like to know if, through the .NET API, it is possible to create customizable properties within the AutoCAD "Properties" Palette.
For example, within the Palette, there are tabs "General", "Geometry" and others, I would like to know if it is possible to create more tabs in this style, and add customizable properties within them.
If anyone can help me or have an example, I would be grateful.
norman.yuan
You cannot do it with AutoCAD .NET API. It can be done with quite involved effort and I would rather use .NET API's PaletteSet to display custom data in most cases.
There have been a few discussion on this topic, such as this:
https://forums.autodesk.com/t5/net/autocad-s-properties-palette-modification/m-p/12341073#M79279
Norman Yuan
Drive CAD With Code
ed57gmc
You might want to read this post. They claim to have accomplished it based on this article.
Ed
How to post your code.
baksconstructor
Here is an example of how it is done - MyPropertiesCAD
