acedGetSym and acedPutSym in .NET applications
Hello, All!
I've wrote a class, which can be helpful in .NET for getting/puttings value of lisp-variables:
[code]
using System;
using System.Runtime.InteropServices;
using System.Text;
using System.Collections;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.AcadLispSym))]
namespace Rivilis
public class AcadLispSym
// From adscodes.h :
// Type of resbuf element
const int RTNONE = 5000; /* No result */
const int RTREAL = 5001; /* Real number */
const int RTPOINT = 5002; /* 2D point X and Y only */
const int RTSHORT = 5003; /* Short integer */
const int RTANG = 5004; /* Angle */
const int RTSTR = 5005; /* String */
const int RTENAME = 5006; /* Entity name */
const int RTPICKS = 5007; /* Pick set */
const int RTORINT = 5008; /* Orientation */
const int RT3DPOINT = 5009; /* 3D point - X, Y, and Z */
const int RTLONG = 5010; /* Long integer */
const int RTVOID = 5014; /* Blank symbol */
const int RTLB = 5016; /* list begin */
const int RTLE = 5017; /* list end */
const int RTDOTE = 5018; /* dotted pair */
const int RTNIL = 5019; /* nil */
const int RTDXF0 = 5020; /* DXF code 0 for ads_buildlist only */
const int RTT = 5021; /* T atom */
const int RTRESBUF = 5023; /* resbuf */
const int RTMODELESS = 5027; /* interrupted by modeless dialog */
// Error return code
const int RTNORM = 5100; /* Request succeeded */
const int RTERROR = -5001; // Some other error
const int RTCAN = -5002; // User cancelled request -- Ctl-C
const int RTREJ = -5003; // AutoCAD rejected request -- invalid
const int RTFAIL = -5004; // Link failure -- Lisp probably died
const int RTKWORD = -5005; // Keyword returned from getxxx() routine
const int RTINPUTTRUNCATED = -5008; // Input didn't all fit in the buffer
[System.Security.SuppressUnmanagedCodeSecurity]
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
// For AutoCAD 2007: CharSet = CharSet.Unicode
// [DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl)]
extern static private int acedGetSym(string args, out IntPtr result);
extern static private int acedPutSym(string args, IntPtr result);
// AcadGetSym
// Fuction get value of lisp-variable
// varname - name of variable
// stat - return code
// Return: ResultBuffer
static public ResultBuffer AcadGetSym(string varname,ref int stat)
IntPtr rb = IntPtr.Zero;
stat = acedGetSym(varname, out rb);
if (stat == (int)PromptStatus.OK && rb != IntPtr.Zero)
return (ResultBuffer) DisposableWrapper.Create(typeof(ResultBuffer), rb, true);
return null;
// AcadPutSym
// Function put new value to lisp-variable
// rb - ResultBufer
// Return: RTNORM - if all right
static public int AcadPutSym(string varname, ResultBuffer rb)
return acedPutSym(varname, rb.UnmanagedObject);
// Test command for geting value of lisp-variable and print it value
[CommandMethod("GetSym")]
static public void GetSym()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
int stat = 0;
PromptResult res = ed.GetString("\nName of lisp-variable: ");
if (res.Status == PromptStatus.OK)
ResultBuffer args = AcadGetSym(res.StringResult,ref stat) ;
if (args != null)
StringBuilder s = new StringBuilder();
s.Append("\n-----------------------------");
foreach (TypedValue val in (IEnumerable) args)
s.AppendFormat("\n{0} -> {1}", val.TypeCode, val.Value.ToString());
ed.WriteMessage(s.ToString());
// Test command for setting value of lisp-variable
[CommandMethod("PutSym")]
static public void PutSym()
ResultBuffer args = new ResultBuffer();
// If I add RTLB and RTLE in AutoCAD 2007 - all right, in AutoCAD 2006
// value of lisp-varible is nil
// args.Add(new TypedValue(RTLB,-1));
args.Add(new TypedValue(RTSTR,"New String"));
// args.Add(new TypedValue(RTLE,-1));
AcadPutSym(res.StringResult,args) ;
[/code]
My question is:
Why in AutoCAD 2006 I can not get/put lisp-variables which is list of atoms (e.g. (= (type var) 'LIST)?
In AutoCAD 2007 I have not problem with this kind of variables.
It seems every time I bring up lisp interaction with dialogs, Tony T says its not possible. Remember the No, No, No
response of the 4/19/2006 thread I started.
I dont doubt that your comments are technically correct, Tony, but I keep seeing more and more lisp communication
routines and now the new attribute in 2007 for doing lisp functions.
It seems at this point, I could at least create a lisp function using .net, that would take params, show a dialog, and
return params. That is a start. Its a little better than using com to communicate with .net since I don't have to
convert variable types.
A .net dialog could also fire lisp functions through the command line, but I thought someone said those functions could
not call the Command lisp function or you get problems. So thats not too great, but I could get around this by closing
the dialog, running the lisp, then reopening. I'm sure Tony is laughing by now, its not ideal I know.
The only thing remaining is how to modify a dialogs controls from lisp. That again could be handled by closing the
dialog and reopening it with desired params. Thats getting rediculous, I know, but there is value in trying to allow
use of existing work done in lisp.
I am not avoiding learning .net, I am simply trying to learn to mix things. Just like I have to mix lisp and dlls from
VB to do what I want many times. I did finally realize I need to read the arx documentation to understand the .net API.
I am walking through the sdk help file of the arx basics. I love new styles of doing things, so its fun. I love making
actual working programs even more though, so I have to get started and set up my library of functions for .net.
One thing I am seeing, is that .net (and arx) has so many lines of code for simple stuff, but its the same pattern over
and over. I am going to set up a library that crunches things down so I have a set of "UFUNS" - remember those from the
old "Maximizing AutoLisp" for R12?
It seems to do that, I should have one param be the transaction object, since constantly making a new one inside each
subroutine is high overhead as I hear.
Anyone got a library going they could share a few examples from?
I am looking for structure type info, like what params do you always pass in (like the trans object) and other patterns.
Then I can stop the lisp comments 🙂
I bet someone could make their website awefully popular by having such a library. Like the Menzi lisp page...
thanks
Alexander Rivilis <>
|>Hello, All!
|>[code]
|>using System;
|>using System.Text;
|>namespace Rivilis
|> // AcadGetSym
|> return null;
|> // AcadPutSym
|> // rb - ResultBufer
|> int stat = 0;
|> if (args != null)
|>[/code]
|>My question is:
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
odurier
I have test this code under AutoCAd Architecture 2011 and it doesn't work
I have set a variable
(setq a "test")
and i have run getsym command
the first time the value is null
the second time the value is good "test"
I have set a other variable (two caracters)
(setq aa "test")
the second time the value is null
Never the value is returned
SOMEONE HAVE AN IDEA?
extern static private int acedGetSym(string name, out IntPtr result);
internal static ResultBuffer GetLispSym(string name)
IntPtr ip = IntPtr.Zero;
acedGetSym(name, out ip);
if (ip != IntPtr.Zero)
ResultBuffer rbRes = ResultBuffer.Create(ip, true);
return rbRes;
return null;
#endregion
Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
int stat = 0;
PromptResult res = ed.GetString("Name of lisp-variable: ");
ResultBuffer args = GetLispSym(res.StringResult);
if (args != null)
foreach (TypedValue val in args)
 MessageBox.Show(val.Value.ToString());
I am loading the AutoCAD2011 today to test the version
of the acedGetSym package invoke routine that I have.
I want to see if I get the same behavior that you are seeing.
If my version works OK... I will post it for you.
Did you test yours on AutoCAD2010?
What happened then?
odurier
After 2 hours of tests i have found the solution
The problem was in the dllimport synthax
I have add "CharSet = CharSet.Unicode"
It work fine now
DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedGetSym")
I had a suspicion that was the problem when reviewing your code.
I think Autodesk changed to Unicode after 2007.
Kean mentioned that in his through the interface blaug.
OK it sounds like you are good to go.
P
