ACA2012 will not install on Windows7 (dotnet Frameworks 4.5)
This widget could not be displayed.
Anyone having issue w/ ACADArch 2012 not able to install on Win7 with .net 4.5 installed.  Based on what I seen dotNet 4.5 is a in-place-replacement of dotnet 4.0.
I just wrote ADN and wanted to check to see if anyOne else is having the same problem.
norman.yuan
You have to install Acad2012 first. That is, remove .NET4.5, install acad, and then reinstall .NET 4.5.
In my case, I installed VS2012 (thus, .NET 4.5) with one of my development box. When later I found I need to install acad2012 in that box, I could not proceed. I had to uninstall .NET 4.5. Then I installed acad2012 and then reinstalled .NET4.5/VS2012.
Norman Yuan
Drive CAD With Code
We are seeing a similar issue.  We are not able to install AutoCAD 2012 SP2 in Windows 7 64-bit with .Net Framework 4.0 and 4.5 installed.  Could it be a problem with the installer not detecting that version 4.0 is installed?
Thanks, Caryn
download and replace, in installer: c:\Autodesk\AutoCAD_2012_Polish_Win_32bit\NETVerifier\setupverifier.exe
cid-27e6a35d1a492af7.skydrive.live.com/self.aspx/Blog%7C_Tools/netfx%7C_setupverifier%7C_new.zip
