Announcements
A block reference with oddly rotated attributes
fsztuczny
fsztuczny
Hello
Below is a link to the drawing. What's the problem:
1. Attributes are defined in the block definition. They look normal, but the rotation angle is 90 degrees. An attempt to set the rotation to 0 degrees results in rotating the attribute to the vertical. Coordinate "Z" attributes in the clouds, but for now I skip this.
2. The angle of rotation of attributes in block inserts depends on the block insert mirror. If the block's X scale changes to positive / negative, the rotation angle of the attribute changes. This behavior is rather unusual.
The above prevents me from processing attributes using their rotation angle. Do you have any ideas?
https://www.dropbox.com/s/uy6mfntaixw3ga7/blokZatrybutamiDziwnieObroconymi.zip?dl=1
Replies (0)
