3Dsolid Mass Properties
k005
k005
Hello friends;
How can I get the Total volumes of a 3Dsolid object or objects with the message box?
I bought the Quantities, but how can I get the Volumes?
Thanks in advance to the helper.
 this.Hide();
            Editor ed = aCap.DocumentManager.MdiActiveDocument.Editor;
            Adb.TypedValue[] filitre = new Adb.TypedValue[1];
            filitre.SetValue(new Adb.TypedValue((int)Adb.DxfCode.Start, "3DSOLID"), 0);
            SelectionFilter acSelFtr = new SelectionFilter(filitre);
            var selection = ed.GetSelection(acSelFtr);
            if (selection.Status != PromptStatus.OK)
                ed.WriteMessage("\n\nKatı obje (3DSOLID) Bulunamadı.\n");
                return;
            if (selection.Status == PromptStatus.OK)
                SelectionSet acsset = selection.Value;
                MessageBox.Show("seçilen 3dsolid sayısı: " +
                                        acsset.Count.ToString());
Alexander.Rivilis
Solid3d.MassProperties.Volume
Facebook | Twitter | LinkedIn
Expert Elite Member
k005
@Alexander.Rivilis
Thank you. How is it used in the message box?
Alexander.Rivilis
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(TotalVolume.MyCommands))]
namespace TotalVolume
    public class MyCommands
        [CommandMethod("TTV")]
        public void TTV()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            if (doc == null) return;
            Editor ed = doc.Editor;
            TypedValue[] filter = new TypedValue[]
                { new TypedValue((int)DxfCode.Start, "3DSOLID") };
            SelectionFilter selFilter = new SelectionFilter(filter);
            PromptSelectionOptions pr = new PromptSelectionOptions();
            pr.MessageForAdding = "Add 3DSolid's for select";
            pr.MessageForRemoval = "Remove 3DSolid's from selection";
            PromptSelectionResult rs = ed.GetSelection(pr, selFilter);
            if (rs.Status == PromptStatus.OK)
                double vol = 0.0;
                using (Transaction tr = doc.TransactionManager.StartTransaction())
                    foreach (ObjectId id in rs.Value.GetObjectIds())
                        Solid3d sol = tr.GetObject(id, OpenMode.ForRead) as Solid3d;
                        if (sol != null)
                            vol += sol.MassProperties.Volume;
                Application.ShowAlertDialog("Total Volume: " + vol.ToString());
Expert Elite Member
k005
@Alexander.Rivilis
Thank you very much. You have completed the missing piece in my work on densities-weights.
