zoom with object in Layout-Viewports
VallimanalanT
VallimanalanT
Am trying to assign a view in layout-viewport through Zoom-->object-->Single-->Groupname (from modelspace). the command execution is not working properly and also unable switch from modelspace to paperspace in layout
 [CommandMethod("LayoutsViews")]
        public void LayoutsViews()
            // Get the current document and database
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            acCurDb.TileMode = false;
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                DBDictionary layoutIDs = acTrans.GetObject(acCurDb.LayoutDictionaryId, OpenMode.ForRead) as DBDictionary;
                // Reference the Layout Manager
                LayoutManager acLayoutMgr = LayoutManager.Current;
                // Step through and list each named layout and Model
                foreach (DBDictionaryEntry layoutID in layoutIDs)
                    Layout CurrentLo = acTrans.GetObject(layoutID.Value, OpenMode.ForRead) as Layout;
                    string layoutName = CurrentLo.LayoutName.ToUpper().ToString();
                    if ((layoutName != "LAYOUT1") && (layoutName != "LAYOUT2") && (layoutName != "MODEL"))
                        //this.viewPort(CurrentLo, layoutName);
                        ObjectIdCollection idCollection = CurrentLo.GetViewports();
                        foreach (ObjectId ID in idCollection)
                            Viewport VP = acTrans.GetObject(ID, OpenMode.ForRead) as Viewport;
                            if (VP != null)
                                VP.UpgradeOpen();
                                VP.On = true;
                                VP.SetDatabaseDefaults();
                                VP.Visible = true;
                                // Activate model space in the viewport
                                acDoc.Editor.SwitchToModelSpace();
                                string command = string.Empty;
                                command = "._zoom _Object _SIngle _Group " + layoutName.ToString() + " ";
                                acDoc.SendStringToExecute(command, true, false, true);
                                acDoc.SendStringToExecute("._regen ", true, false, false);
                                VP.UpdateDisplay();
                                break;
                        ////Activate model space in the viewport
                        //acDoc.Editor.SwitchToPaperSpace();
                    // acDoc.Editor.SwitchToPaperSpace();
                    // Abort the changes to the database
                    acTrans.Commit();
_gile
SenStringToExecute runs asynchronously (i.e. after the method ended).
If you target AutoCAD 2015 or later, you can use the Editor.Command() method.
ed.Command("._zoom", "_Object", "_Group ", layoutName, "");
Gilles Chanteau
GileCAD
GitHub
