Zoom to selected entities
I wrote a simple program which selects some entities from a drawing. Is there a way to zoom to the result programmatically?
{code}
namespace MyExtensionMethods
public static class EditorExtensionMethods
static MethodInfo runCommand = typeof( Editor ).GetMethod(
"RunCommand", BindingFlags.NonPublic | BindingFlags.Instance );
public static PromptStatus Command( this Editor editor, params
object[] args )
return (PromptStatus) runCommand.Invoke( editor, new object[] {
args } );
public static void ZoomObjects( ObjectId[] ids )
Editor editor =
Application.DocumentManager.MdiActiveDocument.Editor;
Application.SetSystemVariable( "CMDECHO", 0 );
Command( editor, "._ZOOM", "_O", ids );
{code}
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6252337@discussion.autodesk.com...
Thanks a lot tony, that's awesome..the only problem is that selected entities are no more highlighted, any suggestion?
You have to reselect them because any command that's started
clears the current selection.
You can use this API to select them:
Autodesk.AutoCAD.Internal.Utils.SelectObjects();
You have to add the CommandFlags.Redraw flag to your command
method attribute for the selection to remain after the command ends.
wrote in message news:6252627@discussion.autodesk.com...
I actually had tried it,
Autodesk.AutoCAD.Internal.Utils.SelectObjects(final_entities);
Autodesk.AutoCAD.Internal.Utils.ZoomObjects(false);
System.Windows.Forms.Application.UseWaitCursor = false;
and also added the CommandFlags.Redraw
The problem is that after zooming, it goes back to its original size, the zoom size does not persist. Edited by: apt42 on Sep 11, 2009 10:53 PM
Tony, how do you go about zooming and selecting in 2009 without internal.utils?
edited... I guess i just needed to add the internal dll to my references. Edited by: ViktorCad on Oct 30, 2009 10:26 PM
You can use Internal.Utils in 2009, you just need to add
a reference to AcMgdInternal.dll.
wrote in message news:6281493@discussion.autodesk.com...
internal.utils?
