Xrecords (going from VBA to .NET)
Message 1 of 20
I have been spinning my wheels for near on 8 months now trying to figure
out how to create (and then read) Xrecords in .NET. Thus far i haven't
found any posts/lessons that have been of any help.
Below are the 2 VBA functions I use to create/read/delete my Xrecords in
AutoCAD. I hope someone can get me going in the right direction (this
little problem stands in my way of moving my applications to .NET).
Thank you to whoever decides to help me 😆
Create:::
Public Function vb_sxr()
Dim TrackingDictionary As AcadDictionary, TrackingXRecord As
AcadXRecord
Dim XRecordDataType As Variant, XRecordData As Variant
Dim DataType As Integer, Data As String, msg As String
Const TYPE_STRING = 1
Const TAG_DICTIONARY_NAME = "TRK Page"
Const TAG_XRECORD_NAME = "Layout"
On Error GoTo Create
Set TrackingDictionary = ThisDrawing.Dictionaries(TAG_DICTIONARY_NAME)
Set TrackingXRecord = TrackingDictionary.GetObject(TAG_XRECORD_NAME)
On Error GoTo 0
TrackingXRecord.GetXRecordData XRecordDataType, XRecordData
If VarType(XRecordDataType) And vbArray = vbArray Then
Else
ReDim XRecordDataType(0) As Integer
ReDim XRecordData(0) As Variant
XRecordDataType(0) = TYPE_STRING: XRecordData(0) =
ThisDrawing.GetVariable("USERS1")
TrackingXRecord.SetXRecordData XRecordDataType, XRecordData
Exit Function
Create:
If TrackingDictionary Is Nothing Then
ThisDrawing.Dictionaries.Add(TAG_DICTIONARY_NAME)
TrackingDictionary.AddXRecord(TAG_XRECORD_NAME)
Resume
End Function
Read:::
Public Function vb_gxr()
AcadXRecord
' Dim iCount As Long
On Error GoTo NONE
On Error GoTo 0
DimSet = XRecordData(0)
Exit Function
NONE:
DimSet = ""
End Function
Delete:::
Public Function vb_rxr()
AcadXRecord
On Error GoTo NONE
On Error GoTo 0
Else
TrackingDictionary.Delete
RemTRKFT
Exit Function
NONE:
End Function
Replies (19)
Message 2 of 20
Did you try searching this newsgroup ?
I seem to recall quite a few posts on the topic, so
maybe a search on 'XRecord' might turn up something.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"C Witt" wrote in message news:5977788@discussion.autodesk.com...
Create:::
AcadXRecord
On Error GoTo 0
Else
Exit Function
Create:
Resume
End Function
Read:::
AcadXRecord
On Error GoTo NONE
On Error GoTo 0
Exit Function
NONE:
DimSet = ""
End Function
Delete:::
AcadXRecord
On Error GoTo NONE
On Error GoTo 0
Else
RemTRKFT
Exit Function
NONE:
End Function
Message 3 of 20
I've looked here a few times. they only seem to deal with xrecords on
objects...?
Message 4 of 20
Try searching on 'NamedObjectsDictionaryId'.
"C Witt" wrote in message news:5978249@discussion.autodesk.com...
objects...?
Message 5 of 20
ok, that gave me a few results (several that i had already looked at).
The only one that "seems" to be what I am after does not look like .NET
code?
        Void(MakeXRecord())
            Xrecord rec=new Xrecord();//Creates a Xrecord object
            rec.Data=new ResultBuffer(
                    new TypedValue((int)DxfCode.Text,
                                        "This is a test"),
                    new TypedValue((int)DxfCode.Int8,0),
                    new TypedValue((int)DxfCode.UcsOrg,
                                      new Point3d(0,0,0))
            );//Use the Data property of Xreord to
              //set the contents of the Xrecord object.
            Tools.AddDictionaryObject("test",rec,
                 Tools.Database.NamedObjectsDictionaryId);
            //Use the AddDictionaryObject() function to add the
            //Xrcord object to AutoCAD database.
            //list the entries we just added
            foreach (TypedValue rb in rec.Data)
               Tools.Editor.WriteMessage(string.Format("TypedCode={0},
                                  Value={1}\n",rb.TypeCode,rb.Value));
Work: VISTA
Ultimate x32 - AMD 64 X2 Dual Core 4200 2.2GHz, 4 Gigs Ram,
color="#666666">GeForce 6800GS 256MB
Home: VISTA Ultimate x64 - AMD 64 Quad
Core 2.2GHz, 8 Gigs Ram, GeForce 8600GT 512MB
Laptop (17" HP): VISTA Premium x32 -
color="#000000">AMD Turion X2 Dual Core TL-50 1.6GHz, 2 Gigs Ram,
color="#666666">Nvidia GeForce 6150
Message 6 of 20
Seems to be working for me
Imports System
Imports System.Reflection
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Interop
Imports System.Windows.Forms.Form
Public Class DictionaryUtils
_
Sub AddXDict()
Dim db As Database = HostApplicationServices.WorkingDatabase
Using trans As Transaction = db.TransactionManager.StartTransaction()
Dim nod As DBDictionary = trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForWrite, False)
Dim dc As DBDictionary
Try
dc = trans.GetObject(nod.GetAt("TestDict"), OpenMode.ForWrite)
Catch
dc = New DBDictionary()
nod.SetAt("TestDict", dc)
trans.AddNewlyCreatedDBObject(dc, True)
End Try
Dim xr As Xrecord
Try
xr = trans.GetObject(dc.GetAt("XREC1"), OpenMode.ForWrite)
Catch
xr = New Xrecord()
xr.Data = New ResultBuffer(New TypedValue(DxfCode.Text, "This a test XRecord"), _
New TypedValue(DxfCode.Angle, 3.14159), _
New TypedValue(DxfCode.Real, 1234.56789), _
New TypedValue(DxfCode.Int32, 1234), _
New TypedValue(DxfCode.Color, 1))
dc.SetAt("XREC1", xr)
trans.AddNewlyCreatedDBObject(xr, True)
End Try
trans.Commit()
End Using
End Sub
Public Shared Sub ReadXrecData(ByVal dictName As String, ByVal xrecName As String)
Try
Dim nod As DBDictionary = CType(trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead), DBDictionary)
Dim dc As DBDictionary = CType(trans.GetObject(nod.GetAt(dictName), OpenMode.ForRead), DBDictionary)
Dim xr As Xrecord
xr = CType(trans.GetObject(dc.GetAt(xrecName), OpenMode.ForRead, False), Xrecord)
Dim rbuf As ResultBuffer = xr.Data
If rbuf Is Nothing Then
MsgBox(ControlChars.CrLf & "Xrecord does not have data attached.")
Else
Dim n As Integer = 0
Dim strRet As String = String.Empty
For Each itm As TypedValue In rbuf
strRet = strRet & String.Format(ControlChars.CrLf & "Item {0}" & ControlChars.Tab & "type: {1}" & ControlChars.Tab & "value: {2}", System.Math.Min(System.Threading.Interlocked.Increment(n), n - 1), itm.TypeCode, itm.Value)
Next
MsgBox(strRet)
rbuf.Dispose()
trans.Commit()
Catch caught As System.Exception
MessageBox.Show(caught.StackTrace)
End Try
End Using
End Sub
End Class
~'J'~
Message 7 of 20
I can't tell you because your posts contain gibberish.
"C Witt" wrote in message news:5978882@discussion.autodesk.com...
The only one that "seems" to be what I am after does not look like .NET code?
       Void(MakeXRecord())
                                       "This is a test"),
                                     new Point3d(0,0,0))
Work: VISTA Ultimate x32 - AMD 64 X2 Dual Core 4200 2.2GHz, 4 Gigs Ram, GeForce 6800GS 256MB
Home: VISTA Ultimate x64 - AMD 64 Quad Core 2.2GHz, 8 Gigs Ram, GeForce 8600GT 512MB
Laptop (17" HP): VISTA Premium x32 - AMD Turion X2 Dual Core TL-50 1.6GHz, 2 Gigs Ram, Nvidia GeForce 6150
Message 8 of 20
Forgot to say that this code was stealed from Lab4
Take a look at CreateDivision sub from there
~'J'~
Message 9 of 20
I didn't know the labs had an XRecprd example.
Why didn't you go through the labs in the first place?
       Void(MakeXRecord())
                                       "This is a test"),
                                     new Point3d(0,0,0))
Message 10 of 20
Sorry,
I have the big disorder in my files,
therefore I have recollected just after I have sent
my response to this thread
~'J'~
Message 11 of 20
Here is this code I have talking about
-------------snip
Private Sub CreateDivision()
'First, get the NOD...
Dim NOD As DBDictionary = trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForWrite, False)
'Define a corporate level dictionary
Dim acmeDict As DBDictionary
Try
'if it exists, just get it
acmeDict = trans.GetObject(NOD.GetAt("ACME_DIVISION"), OpenMode.ForRead)
Catch
'Doesn't exist, so create one
acmeDict = New DBDictionary()
NOD.SetAt("ACME_DIVISION", acmeDict)
trans.AddNewlyCreatedDBObject(acmeDict, True)
End Try
'Now get the division we want from acmeDict
Dim divDict As DBDictionary
Try
divDict = trans.GetObject(acmeDict.GetAt("Sales"), OpenMode.ForWrite)
Catch
divDict = New DBDictionary() 'Division doesn't exist, create one
acmeDict.UpgradeOpen()
acmeDict.SetAt("Sales", divDict)
trans.AddNewlyCreatedDBObject(divDict, True)
End Try
'Now get the manager info from the division
'We need to add the name of the division supervisor. We'll do this with another XRecord.
Dim mgrXRec As Xrecord
Try
mgrXRec = trans.GetObject(divDict.GetAt("Department Manager"), OpenMode.ForWrite)
Catch
mgrXRec = New Xrecord()
mgrXRec.Data = New ResultBuffer(New TypedValue(DxfCode.Text, "Randolph P. Brokwell"))
divDict.SetAt("Department Manager", mgrXRec)
trans.AddNewlyCreatedDBObject(mgrXRec, True)
End Try
trans.Commit()
End Using
End Sub
---------snip
~'J'~
Message 12 of 20
This is what I have now.. (mostly from the labs).  But either my "get"
program is really wrong..  or the "set" does not work..?
Unfortunately the labs demo has the Xrecord attached to a block..  I
don't want it attached to anything..?
    <CommandMethod("test-set")> _
    Public Sub Create_Page_Xrecord() 'Public Sub
Create_Page_Xrecord(ByVal Page_String As String)
        Dim db = HostApplicationServices.WorkingDatabase
        Dim trans As Transaction =
db.transactionmanager.starttransaction
        Try
trans.GetObject(db.namedobjectsdictionaryid, OpenMode.ForWrite, False)
            Dim TRKDict As DBDictionary
            Try
                TRKDict = trans.GetObject(NOD.GetAt("TRK Settings"),
OpenMode.ForRead)
            Catch
                TRKDict = New DBDictionary
                NOD.SetAt("TRK Settings", TRKDict)
                trans.AddNewlyCreatedDBObject(TRKDict, True)
            End Try
            Dim PageDict As DBDictionary
            Try
                PageDict = trans.GetObject(TRKDict.GetAt("Page
Settings"), OpenMode.ForWrite)
            Catch
                PageDict = New DBDictionary()
                TRKDict.UpgradeOpen()
                TRKDict.SetAt("Page Settings", PageDict)
                trans.AddNewlyCreatedDBObject(PageDict, True)
            End Try
            Dim SettingsXRec As Xrecord
            Try
                SettingsXRec = trans.GetObject(PageDict.GetAt("Settings
Info"), OpenMode.ForWrite)
            Catch
                SettingsXRec = New Xrecord()
                SettingsXRec.Data = New ResultBuffer(New
TypedValue(DxfCode.Text, "test"))
                PageDict.SetAt("Settings Info", SettingsXRec)
                trans.AddNewlyCreatedDBObject(SettingsXRec, True)
            End Try
            trans.Commit()
        Finally
            trans.Dispose()
        End Try
    End Sub
    <CommandMethod("test-get")> _
    Public Sub Read_Page_Xrecord() 'Public Function Read_Page_Xrecord()
As String
        Dim DimsetXrecExists As Boolean = True
        Dim XrecValue As String
        Try
trans.GetObject(db.namedobjectdictionaryid, OpenMode.ForRead, False)
            Dim TRKDict As DBDictionary =
trans.GetObject(NOD.GetAt("TRK Settings"), OpenMode.ForRead)
            Dim PageDict As DBDictionary =
trans.GetObject(TRKDict.GetAt("Page Settings"), OpenMode.ForRead)
Info"), OpenMode.ForRead)
            XrecValue = SettingsXRec.Data.AsArray(0).ToString
        Catch
            DimsetXrecExists = False
        End Try
        If DimsetXrecExists Then
            'Read_Page_Xrecord = XrecValue
            MsgBox(XrecValue, MsgBoxStyle.Information)
        Else
            'Read_Page_Xrecord = ""
            MsgBox("nothing found", MsgBoxStyle.Information)
    End Sub
Work: VISTA
Message 13 of 20
ok, I've refined the code (and found the "error" i had before).   So I
can "set" and "read" the xrecord just like I did in VBA..  now I'm left
with how to I change it once created?    Can it be done (if so how?),
or do I have to recreate the xrecord (again, how?)?
Work: VISTA
        Try
            Try
OpenMode.ForRead)
            Catch
            End Try
            Try
            Catch
            End Try
            Try
            Catch
            End Try
            trans.Commit()
        Finally
            trans.Dispose()
        End Try
    End Sub
As String
        Try
        Catch
        End Try
        Else
    End Sub
Work: VISTA
Quad
Message 14 of 20
Looks like that has been solved too.
Work: VISTA
Work: VISTA
Quad
        Try
            Try
OpenMode.ForRead)
            Catch
            End Try
            Try
            Catch
            End Try
            Try
            Catch
            End Try
            trans.Commit()
        Finally
            trans.Dispose()
        End Try
    End Sub
As String
        Try
        Catch
        End Try
        Else
    End Sub
Work: VISTA
Quad
Message 15 of 20
Sorry, your post are unreadable.
Try looking at one of your posts with Outlook Express
It's all gibberish.
"C Witt" wrote in message news:5980821@discussion.autodesk.com...
This is what I have now.. (mostly from the labs). But either my "get" program is really wrong.. or the "set" does not work..?
Unfortunately the labs demo has the Xrecord attached to a block.. I don't want it attached to anything..?
   _
   Public Sub Create_Page_Xrecord() 'Public Sub Create_Page_Xrecord(ByVal Page_String As String)
       Dim trans As Transaction = db.transactionmanager.starttransaction
       Try
           Dim NOD As DBDictionary = trans.GetObject(db.namedobjectsdictionaryid, OpenMode.ForWrite, False)
           Try
               TRKDict = trans.GetObject(NOD.GetAt("TRK Settings"), OpenMode.ForRead)
           Catch
           End Try
           Try
               PageDict = trans.GetObject(TRKDict.GetAt("Page Settings"), OpenMode.ForWrite)
           Catch
           End Try
           Try
               SettingsXRec = trans.GetObject(PageDict.GetAt("Settings Info"), OpenMode.ForWrite)
           Catch
               SettingsXRec.Data = New ResultBuffer(New TypedValue(DxfCode.Text, "test"))
           End Try
           trans.Commit()
       Finally
           trans.Dispose()
       End Try
   End Sub
   _
   Public Sub Read_Page_Xrecord() 'Public Function Read_Page_Xrecord() As String
       Try
           Dim NOD As DBDictionary = trans.GetObject(db.namedobjectdictionaryid, OpenMode.ForRead, False)
           Dim TRKDict As DBDictionary = trans.GetObject(NOD.GetAt("TRK Settings"), OpenMode.ForRead)
           Dim PageDict As DBDictionary = trans.GetObject(TRKDict.GetAt("Page Settings"), OpenMode.ForRead)
           SettingsXRec = trans.GetObject(PageDict.GetAt("Settings Info"), OpenMode.ForRead)
       Catch
       End Try
       Else
   End Sub
Message 16 of 20
His posts show fine here in Outlook Express 6 - I only see the Â's in your post backs. Maybe a setting you have?
"Tony Tanzillo" wrote in message news:5981159@discussion.autodesk.com...
It's all gibberish.
   _
       Try
           Try
           Catch
           End Try
           Try
           Catch
           End Try
           Try
           Catch
           End Try
           trans.Commit()
       Finally
           trans.Dispose()
       End Try
   End Sub
   _
       Try
       Catch
       End Try
       Else
   End Sub
Message 17 of 20
OE 6 here as well, everything set to defaults, with Unicode encoding.
"Paul Richardson" wrote in message news:5981169@discussion.autodesk.com...
It's all gibberish.
   _
       Try
           Try
           Catch
           End Try
           Try
           Catch
           End Try
           Try
           Catch
           End Try
           trans.Commit()
       Finally
           trans.Dispose()
       End Try
   End Sub
   _
       Try
       Catch
       End Try
       Else
   End Sub
Message 18 of 20
They look fine to me (checked outlook on another computer).   Only your
posts show that extra formatting..?
Work: VISTA
Message 19 of 20
Paul Richardson wrote:
> His posts show fine here in Outlook Express 6 ...
Also look fine in Thunderbird 2.0.
Terry
Message 20 of 20
I was using Western European - changing to Unicode 8 does not give me any Â's. Maybe because
I've already downloaded his posts. We'll see with future posts...
"Tony Tanzillo" wrote in message news:5981200@discussion.autodesk.com...
It's all gibberish.
   _
       Try
           Try
           Catch
           End Try
           Try
           Catch
           End Try
           Try
           Catch
           End Try
           trans.Commit()
       Finally
           trans.Dispose()
       End Try
   End Sub
   _
       Try
       Catch
       End Try
       Else
   End Sub
