WriteDsd method get exception randomly
ptranU2KHX
ptranU2KHX
Hi everyone,
I am experiencing an issue that is quite weird, it happens randomly so I can not trace the cause.
In my code, when I create Dsd file using DsdData.WriteDsd method, sometimes I get this exception with the message "Operation is not valid due to the current state of the object."
Do you have any ideas about why this happens? Thank you in advance.
*UPDATED
Here is a partial block of my work
Public Sub Publish(ByVal dsdFile As String, ByVal dsdColl As DsdEntryCollection, ByVal plotFile As String, ByVal shType As SheetType)
        Dim dsData As New DsdData()
        dsData.SetDsdEntryCollection(dsdColl)
        dsData.SheetType = shType
        dsData.NoOfCopies = 1
        dsData.DestinationName = plotFile
        dsData.WriteDsd(dsdFile)
ptranU2KHX
I really need help!
_gile
If you want someone to help you, you need to provide more details.
Finding the origin of a "random" exception is often very difficult, but doing so without seeing a line of code is impossible.
You should at least post the code of the method which throws the exception and describe the context this method runs.
Gilles Chanteau
GileCAD
GitHub
ptranU2KHX
@_gile thank you for your help. I did not realize this. I have just updated this post.
