Write data to the NOD before document closes?
nshupeFMPE3
nshupeFMPE3
I'm trying to find what event would be the best to react to in in order to write data to the NOD before the document closes. I've tried reacting to
Application.DocumentManager.DocumentDestroyed += new DocumentDestroyedEventHandler(docColDocDestroyed)
but get an error when trying to create a transaction.
And when I try to react to
Document.BeginDocumentClose
I get an eLockedViolation. The violation comes from an external assembly that I cant change, and I need the assembly for backwards compatibility (I'm only doing this part for backwards compatibility.)
Any help would be greatly appreciated!
_gile
Try to handle the DocumentToBeDestroyed event and, in the event handler, use an OpenCloseTransaction instead of a standard Transaction.
Gilles Chanteau
GileCAD
GitHub
nshupeFMPE3
that appears to have worked, thank you Sir!
nshupeFMPE3
it appears that the Transaction completes without failing, but that the changes are not saved to the NOD as the changes do not appear when opening the file again.
_gile
You have to save the document.
This works for me:
        private void Docs_DocumentToBeDestroyed(object sender, DocumentCollectionEventArgs e)
            var db = e.Document.Database;
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                var nod = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                DBDictionary dict;
                if (nod.Contains("FOO"))
                    dict = (DBDictionary)tr.GetObject(nod.GetAt("FOO"), OpenMode.ForRead);
                else
                    dict = new DBDictionary();
                    nod.UpgradeOpen();
                    nod.SetAt("FOO", dict);
                    tr.AddNewlyCreatedDBObject(dict, true);
                Xrecord xrec;
                if (dict.Contains("Bar"))
                    xrec = (Xrecord)tr.GetObject(dict.GetAt("Bar"), OpenMode.ForWrite);
                else
                    xrec = new Xrecord();
                    if (!dict.IsWriteEnabled)
                        dict.UpgradeOpen();
                    dict.SetAt("Bar", xrec);
                    tr.AddNewlyCreatedDBObject(xrec, true);
                xrec.Data = new ResultBuffer(new TypedValue(1, "baz"));
                tr.Commit();
            dynamic acadDoc = e.Document.GetAcadDocument();
            acadDoc.Save();
Gilles Chanteau
GileCAD
GitHub
SRSDS
Does this save the document on closing regardless of whether or not the user has chosen not to?
Your solution here is another which doesn't. https://forums.autodesk.com/t5/net/how-to-catch-save-quit-document/m-p/8321676#M60415
