WPF vb.net ShowModelessWindow prevent multiple instances
budinsky
budinsky
I would like to have a MainWindow open as modeless so it can stay open, but calling the command again results in multiple modeless windows. How can I check if the MainWindow is already open to prevent multiples?
<CommandMethod("BatchProcess")> Public Sub cmdBatchProcess()
  Dim winBatPro As New MainWindow
  Application.ShowModelessWindow(winBatPro)
End Sub
jabowabo
Try this (you'll have to translate to VB):
            // check if form is already open
            Form_MyForm myForm;
            bool isFormOpen = false;
            FormCollection fc = System.Windows.Forms.Application.OpenForms;
            foreach (Form frm in fc)
                if (frm.Name == "Form_MyForm")
                    isFormOpen = true;
                    if (frm.WindowState == FormWindowState.Minimized)
                        frm.WindowState = FormWindowState.Normal;
                    myForm = (Form_MyForm)frm;
                    break;
            if (!isFormOpen)
                myForm = new Form_MyForm();
                myForm.Show();
norman.yuan
Firstly, you need to be careful to use modeless form/window: in most cases one only use it for showing information in application context; if the information shown on the form/window is specific document (for example, the active drawing in AutoCAD) related, because user can switch to another document while this form/window shows. In this case, you need to either refresh the content on the form with newly activated document, or you need to have the form/window closed automatically.
In general, for modeless form/window/paletteset, only a static/Shared instance is created, something like:
<CommandClass> _
Public MyCommandClass
  Private Shared _floatWindow As MainWindow=Nothing
  <CommandMethod("DoSomthing", CommandFlags.Session>
  Public Shared Sub DoSomethingWithFloatForm()
    If _floatWindow Is Nothing Then
        _floatWindow=New MainWindow
    Application.ShowModelessWindow(_floatWidnow)
  End Sub
End Class
You also need to handle the window's Closing event, where you cancel the closing, and set the window's Visible/Visibility property to False/Hide, so that when user clicks the "x" on the window, it is not closed, but becomes hidden instead.
You can also use multiple floating forms/windows with each related to specific open drawing. This article might be helpful on this regard:
https://drive-cad-with-code.blogspot.com/2014/02/showing-and-closing-modeless-formdialog.html
HTH
Norman Yuan
Drive CAD With Code
budinsky
Thanks so much! I appreciate both of your replies. You guys rock!
MainWindow is not drawing specific so no need to refresh anything.
Had not considered minimising the window, now it keeps my data - very awesome!
I'm still learning so this took me all night to work out but I'm better for it.
