why two CAD blockreference's shape is different
wokeyiyognshenme
wokeyiyognshenme
in the dwg,two blockreference  has same name ,same rotation.
but why do they have different shape, different basepoint ?
_gile
The block on the left does not lies on the XY plane, its normal is: 0.0168726, 0.0, 0.999858 (slightly rotated on Y axis).
The Rotation property of a block reference is measuered about the X axis of the Object Corrdinate System (OCS).
Gilles Chanteau
GileCAD
GitHub
wokeyiyognshenme
 How to reproduce this problem。
do you mean
1。first,  set a ocs, forexamble, its Zaxis is (a,b,c).
2。second ,insert a blockreference in the OCS ?
I DON'T know how to draw. could you give a Operation video ---Screen recording。
thank you .
_gile
Gilles Chanteau
GileCAD
GitHub
wokeyiyognshenme
great!!!
thank your very much.
another problem:
the left blockreference is not drawed in wcs.
how to get the four point(X,Y,z) of the rectangle in wcs
_gile
You can either get the coordinates of the polyline by exploding the block reference or from the block definition.
        public static Point3dCollection GetPolylineCoordinates(Polyline pline)
            var points = new Point3dCollection();
            for (int i = 0; i < pline.NumberOfVertices; i++)
                points.Add(pline.GetPoint3dAt(i));
            return points;
        private static Point3dCollection GetPolylineCoordinatesByExploding(BlockReference br)
            var entitySet = new DBObjectCollection();
            br.Explode(entitySet);
            foreach (Entity entity in entitySet)
                if (entity is Polyline pline)
                    points = GetPolylineCoordinates(pline);
                entity.Dispose();
            return points;
        private static Point3dCollection GetPolylineCoordinatesFromBlockDefinition(BlockReference br)
            var btr = (BlockTableRecord)br.BlockTableRecord.GetObject(OpenMode.ForRead);
            foreach (ObjectId id in btr)
                if (id.ObjectClass.Name == "AcDbPolyline")
                    var pline = (Polyline)id.GetObject(OpenMode.ForRead);
                    foreach (Point3d point in GetPolylineCoordinates(pline))
                        points.Add(point.TransformBy(br.BlockTransform));
            return points;
Gilles Chanteau
GileCAD
GitHub
wokeyiyognshenme
thankyou very much
