why segment of curves created by region boundary is missing
Brainstormcn
Message 1 of 11
Brainstormcn
[CommandMethod("testregion")]
        public void RegionSubstr()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            //var ent1 = ed.GetEntity("\nSelect Curve");
            //建立选择集过滤
            TypedValueList tv = new TypedValueList();
            tv.Add(0, "*line");
            SelectionFilter fil = new SelectionFilter(tv);
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForAdding = "\n select curves:";
            PromptSelectionResult psr = ed.GetSelection(pso, fil);
            if (psr.Status != PromptStatus.OK)
                ed.WriteMessage("\n selection is null!");
                return;
            PromptEntityResult ent = ed.GetEntity("\nselect curve to be substracted:");
            using (var tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                ObjectId oId = ent.ObjectId;
                Entity entity2 = tr.GetObject(oId, OpenMode.ForWrite) as Entity;
                var curveSegments = new DBObjectCollection();
                foreach (var id in psr.Value.GetObjectIds())
                    curveSegments.Add(tr.GetObject(id, OpenMode.ForRead) as Entity);
                var regions = Region.CreateFromCurves(curveSegments);
                var region1 = regions[0] as Region;
                var region2 = Region.CreateFromCurves(new DBObjectCollection { entity2 })[0] as Region;
                if (region1 != null)
                    region1.BooleanOperation(BooleanOperationType.BoolSubtract, region2);
                    Brep brep = new Brep(region1);
                    BrepFaceCollection faces = brep.Faces;
                    BoundaryLoop boundaryLoop = faces.First().Loops.First();
                    Edge[] boundaryEdges = boundaryLoop.Edges.ToArray();
                    Curve3d[] cv3 = new Curve3d[boundaryEdges.Count()];
                    for (int i = 0; i < boundaryEdges.Count(); i++)
                        cv3[i] = (boundaryEdges[i].Curve as ExternalCurve3d).NativeCurve;
                    CompositeCurve3d cc3 = new CompositeCurve3d(cv3);
                    var newCv1 = Curve.CreateFromGeCurve(cc3);
                    newCv1.ColorIndex = 1;
                    btr.AppendEntity(newCv1);
                    tr.AddNewlyCreatedDBObject(newCv1, true);
                tr.Commit();
Replies (10)
Message 2 of 11
_gile
I'ts impossible to reply you without seeing a drawing (i.e. what contains the selection set and what is the selected entity).
Anyway, your code is only interested in the first loop of the face, it does not take into account a possible island in the region.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 11
Brainstormcn
Hi gile,thans for your reply. Here I attached the drawing with problems and the reviesed tread.Pls kindly help me to find what causing the segement missing.
[CommandMethod("TESTREGION")]
            //selection filter
            TypedValue[] filter = new TypedValue[] { new TypedValue(0, "*line" )};
            SelectionFilter fil = new SelectionFilter(filter);
                ed.WriteMessage("\n selection is empty!");
                return;
            PromptEntityResult promptEntityResult = ed.GetEntity("\nselect curve to be substracted:");
            if (promptEntityResult.Status != PromptStatus.OK) return;
                ObjectId oId = promptEntityResult.ObjectId;
                Entity ent = tr.GetObject(oId, OpenMode.ForWrite) as Entity;
                //make regions form curveSegments
                //region to substrcat from
                var regionSubstrcatFrom = regions[0] as Region;
                var regionSubstrcat = Region.CreateFromCurves(new DBObjectCollection { ent })[0] as Region;
                if (regionSubstrcatFrom != null)
                    regionSubstrcatFrom.BooleanOperation(BooleanOperationType.BoolSubtract, regionSubstrcat);
                    Brep brep = new Brep(regionSubstrcatFrom);
                tr.Commit();
Message 4 of 11
Brainstormcn
Here is the problem drawing.
Message 5 of 11
_gile
There's a missing segment because the generated polyline is not closed (Closed properrty).
Beside this, your code is not very safe because you do not check the number of created regions or loops and do not dispose them.
Here's a more robust implementation.
        [CommandMethod("TEST")]
        public static void Test()
            var filter = new SelectionFilter(new[] { new TypedValue(0, "LINE,LWPOLYLINE") });
            var pso = new PromptSelectionOptions();
            pso.MessageForAdding = "\nSelect curves: ";
            var psr = ed.GetSelection(pso, filter);
                return;
                if (!TryCreateRegion(psr.Value.GetObjectIds(), tr, out Region region1))
                    ed.WriteMessage("\nFailed to create a region.");
                    return;
                using (region1)
                    var peo = new PromptEntityOptions("\nSelect a curve to be substracted: ");
                    peo.SetRejectMessage("\nMust be a curve.");
                    peo.AddAllowedClass(typeof(Curve), false);
                    var per = ed.GetEntity(peo);
                    if (per.Status != PromptStatus.OK)
                        return;
                    if (!TryCreateRegion(new[] { per.ObjectId }, tr, out Region region2))
                        return;
                    using (region2)
                        var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        if (TryCreatePolylineFromRegion(region1, out Polyline pline))
                            region1.Dispose();
                            pline.ColorIndex = 3;
                            curSpace.AppendEntity(pline);
                            tr.AddNewlyCreatedDBObject(pline, true);
                        else
                            region1.ColorIndex = 1;
                            curSpace.AppendEntity(region1);
                            tr.AddNewlyCreatedDBObject(region1, true);
                tr.Commit();
        private static bool TryCreateRegion(ObjectId[] curveIds, Transaction tr, out Region region)
            region = null;
            foreach (ObjectId id in curveIds)
                curveSegments.Add(tr.GetObject(id, OpenMode.ForRead));
            if (regions.Count != 1)
                if (1 < regions.Count)
                    foreach (DBObject dBObject in regions)
                        dBObject.Dispose();
                return false;
            region = (Region)regions[0];
            return true;
        private static bool TryCreatePolylineFromRegion(Region region, out Polyline pline)
            pline = null;
            using (var brep = new Brep(region))
                var face = brep.Faces.First();
                if (1 < face.Loops.Count())
                    return false;
                var loop = face.Loops.First();
                var compositeCurve = new CompositeCurve3d(
                    loop.Edges
                    .Select(e => ((ExternalCurve3d)e.Curve).NativeCurve)
                    .ToArray());
                var curve = Curve.CreateFromGeCurve(compositeCurve);
                if (curve is Polyline)
                    pline = (Polyline)curve;
                    pline.Closed = true;
                    return true;
                return false;
Gilles Chanteau
GileCAD
GitHub
Message 6 of 11
_gile
Here's another implementation which makes an union of the regions created from the first selection.
            region = null;
            if (regions.Count == 0)
                return false;
            for (int i = 1; i < regions.Count; i++)
                region.BooleanOperation(BooleanOperationType.BoolUnite, (Region)regions[i]);
                regions[i].Dispose();
            return true;
            pline = null;
                if (1 < brep.Complexes.Count())
                    return false;
                    return false;
                    loop.Edges
                    .ToArray());
                    return true;
                return false;
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
_gile
I'd try to do something more generic to get the curves making up the boundaries of a region, including any islands and separate boundary. If the boundary allows it, the returned curve is a closed polyline.
using Autodesk.AutoCAD.BoundaryRepresentation;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using System.Collections.Generic;
using System.Linq;
namespace Gile.AutoCAD.Geometry
    public static class Extension
        /// <summary>
        /// Gets the curves constituting the boundaries of the region.
        /// </summary>
        /// <param name="region">The region this method applies to.</param>
        /// <returns>Curve collection.</returns>
        public static IEnumerable<Curve> GetCurves(this Region region)
                var loops = brep.Complexes
                    .SelectMany(complex => complex.Shells)
                    .SelectMany(shell => shell.Faces)
                    .SelectMany(face => face.Loops);
                foreach (var loop in loops)
                    var curves3d = loop.Edges
                        .Select(edge => ((ExternalCurve3d)edge.Curve).NativeCurve);
                    Curve curve;
                    if (1 < curves3d.Count())
                        if (curves3d.All(curve3d => curve3d is CircularArc3d || curve3d is LineSegment3d))
                            if (!curves3d.First().EndPoint.IsEqualTo(curves3d.Skip(1).First().StartPoint))
                                curves3d = curves3d
                                    .Reverse()
                                    .Select(curve3d =>
                                        curve3d is CircularArc3d ?
                                        curve3d.GetReverseParameterCurve() : curve3d);
                            curve = Curve.CreateFromGeCurve(new CompositeCurve3d(curves3d.ToArray()));
                            ((Polyline)curve).Closed = true;
                            yield return curve;
                        else
                            foreach (Curve3d curve3d in curves3d)
                                yield return Curve.CreateFromGeCurve(curve3d);
                    else
                        yield return Curve.CreateFromGeCurve(curves3d.First());
Gilles Chanteau
GileCAD
GitHub
Message 8 of 11
Brainstormcn
Thanks _gile. Learn a lot from this thread and your other posts.like your programming characteristic of using Ling programma.
And thanks for pointing out the defects of my codes,Indeed there are many things that I dont handle.
As for this post ,I found a new problem : the  bool result is not as expected if the polyline has circular segments.
see picture below and attached the drawing .
Message 9 of 11
_gile
OK, I think I fixed it.
We have order and/or reverse the curves of the loop before passing them the CompositeCurve3d constructor.
Here're the new extension methods.
using System;
using System.Linq;
        /// <summary>
        /// </summary>
                    var curves3d = loop.Edges.Select(edge => ((ExternalCurve3d)edge.Curve).NativeCurve);
                            var pline = (Polyline)Curve.CreateFromGeCurve(new CompositeCurve3d(curves3d.ToOrderedArray()));
                            yield return pline;
                        else
                    else
        /// <summary>
        /// Order the collection by contiguous curves ([n].EndPoint equals to [n+1].StartPoint)
        /// </summary>
        /// <param name="source">Collection this method applies to.</param>
        /// <returns>Ordered array of Curve3d.</returns>
        public static Curve3d[] ToOrderedArray(this IEnumerable<Curve3d> source)
            var list = source.ToList();
            int count = list.Count;
            var array = new Curve3d[count];
            int i = 0;
            array[0] = list[0];
            list.RemoveAt(0);
            int index;
            while (i < count - 1)
                var pt = array[i++].EndPoint;
                if ((index = list.FindIndex(c => c.StartPoint.IsEqualTo(pt))) != -1)
                    array[i] = list[index];
                else if ((index = list.FindIndex(c => c.EndPoint.IsEqualTo(pt))) != -1)
                    array[i] = list[index].GetReverseParameterCurve();
                else
                    throw new ArgumentException("Not contiguous curves.");
                list.RemoveAt(index);
            return array;
Gilles Chanteau
GileCAD
GitHub
Message 10 of 11
Brainstormcn
Thanks _gile, it works. Method of ToOrderedArray is helpfull for me .It can be used to reorder lines / plines that are connected end-to-end.
Thansk again.
Message 11 of 11
Civil3DReminders_com
The code works great.
There is an issue I ran into where the GetCurves method is returning objects with an ECS that is not aligned with WCS. I had to change the ECS to WCS to be able to use the polylines and get the expected results.
My previous post didn't work. Here is a revised method using the GeometryExtensions from GileCAD
http://www.theswamp.org/index.php?PHPSESSID=b5a2ca0a05e981d0178d243f06127a41&topic=31865.0
http://gilecad.azurewebsites.net/Default.aspx
var mWPlane = Matrix3d.WorldToPlane(poly.Normal);
var polySegments = new PolylineSegmentCollection(poly, mWPlane);
                    var transformedPolySegments = polySegments.Join();
                    foreach (var transformedPolySegmentColl in transformedPolySegments)
                        var transformedPoly = transformedPolySegmentColl.ToPolyline();
                        joinedAreas.Add(new SubassemblyArea(transformedPoly, "Joined", "Joined"));
        /// <summary>
        /// Creates a new instance of PolylineSegmentCollection from a Polyline and converts
        /// the OCS to WCS.
        /// </summary>
        /// <param name="pline">A Polyline instance.</param>
        public PolylineSegmentCollection(Polyline pline, Matrix3d ocsToWcs)
            int n = pline.NumberOfVertices - 1;
            for (int i = 0; i < n; i++)
                _contents.Add(new PolylineSegment(
                    pline.GetPoint2dAt(i).ToPoint3d().TransformBy(ocsToWcs).ToPoint2d(),
                    pline.GetPoint2dAt(i + 1).ToPoint3d().TransformBy(ocsToWcs).ToPoint2d(),
                    pline.GetBulgeAt(i),
                    pline.GetStartWidthAt(i),
                    pline.GetEndWidthAt(i)));
            if (pline.Closed == true)
                    pline.GetPoint2dAt(n).ToPoint3d().TransformBy(ocsToWcs).ToPoint2d(),
                    pline.GetPoint2dAt(0).ToPoint3d().TransformBy(ocsToWcs).ToPoint2d(),
                    pline.GetBulgeAt(n),
                    pline.GetStartWidthAt(n),
                    pline.GetEndWidthAt(n)));
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
