Which property of DBObject can determine that the entity has been modified?
Which property of DBObject or Entity can determine that the entity has been modified. For example, if I modify entity A, after saving it, I will judge whether entity A has been modified. It is also possible that there are other entities in the drawing, only other entities are modified, entity A is not modified, and then the drawing is saved. At this time, I use the program to judge whether entity A has been modified. If it is not modified, it will not operate. If there is modification, the required code will be executed.thanks in advance.
