What assembly is AeccCivilBatchConverter command from?
JamesMaeding
Advisor Advisor
JamesMaeding
I am seeing some funny issues, and want to compare file dates and things.
I am on c3d 2018 but its likely the same for all versions.
I actually do not know if its from a .net assembly, but if anyone knows where its from, that would be helpful.
thanks
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
ActivistInvestor
thanks
Console.Write(typeof(AeccCivilBatchConverter).Assembly.Filename);
ActivistInvestor
thanks
If its a managed type, its from an assembly.
Use GetType().Assembly.Filename to find out the name of the .dll
JamesMaeding
Its a command though, not an object type.
Ignore if you knew that.
I tried to find with ARX, Command on command line, but did not see it.
There was a lot so I may have missed it.
Should that have worked?
Will commands from .net assemblies show using the ARX Command listing technique?
thx
ActivistInvestor
Search the Commands key of the registry for a registered application that registers that command name. If found, it could be a native or managed application.
thx
JamesMaeding
You nailed it. I wasn't thinking it would be loaded that way but there it was.
Answer is its from:
C:\Program Files\Autodesk\AutoCAD 2015\C3D\AeccISDBatchConverter.arx
reg key is:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R20.0\ACAD-E000:409\Applications\AeccCivilBatchConverter\Commands
add another solution to your belt.
