Visual Studio Community 2022
fsl88
fsl88
Hello everyone,
I'm using Autocad 2017, and upgraded to VS 2022 community from VS 2013 and I cannot debug, but I can rebuild or build solutions. Is there any option I'm missing? With my previous VS2013 I'm not having this problem.
norman.yuan
You may want to explain what exactly "cannot debug" mean. I tried VS2022 Community version with Acad2019/2020/2021 and had no issue so far. I am not sure older Acad version (Acad2017) would have issues or not, but I assume it would be ok, unless you can provide more specific details related to older AutoCAD version.
Norman Yuan
Drive CAD With Code
fsl88
Hello.
After loading the dll using netload and type the command on the command line, it says "Unknown command" .
Also as pictured below, I think this has something to do with the error.
