Visual Studio 2017 C# .net WPF within Autocad
Message 1 of 16
I am using AutoCAD Mechanical 2016, and Visual Studio 2017 (.net C#).
I have some code that I would like to use a WPF within AutoCAD to control.
I tried looking for some AutoCAD WPF tutorials with .net but all of them seem to be missing the basic introduction to it.
The link below is a good example of how to accomplish this task..but when I try to utilize this example I get a few issues with it.
http://through-the-interface.typepad.com/through_the_interface/2014/05/adding-a-wpf-document-tab-in-...
The main issue is, when the palette shows, it is just a blank box and doesn't show a button I added or any of the stuff the example showed.
My main question is:
Is there a really good recent example that shows the most basic uses utilizing a WPF within AutoCAD?
Replies (15)
Message 2 of 16
_gile
To add a WPF modal dialog to your AutoCAD plugin project, you have to add a "User Control (WPF)" to the project and replace Usercontrol with Window in both the xaml and xaml.cs files.
Here's a minimalist example:
XAML:
<Window x:Class="SimpleWpfModalDialog.ModalDialog"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:local="clr-namespace:SimpleWpfModalDialog"
             mc:Ignorable="d" Height="160" Width="300">
    <Grid Background="WhiteSmoke">
        <Grid.RowDefinitions>
            <RowDefinition Height="Auto"/>
        </Grid.RowDefinitions>
        <Label Grid.Row="0" Margin="5">Enter your name:</Label>
        <TextBox x:Name="nameBox" Grid.Row="1" Margin="5"/>
        <Button x:Name="okButton" Grid.Row="2" Margin="10" HorizontalAlignment="Center" Content="OK" Height="24" Width="80" Click="okButton_Click"/>
    </Grid>
</Window>
Code behind (xaml.cs)
using System.Windows;
namespace SimpleWpfModalDialog
    public partial class ModalDialog : Window
        public ModalDialog()
            InitializeComponent();
        public string UserName => nameBox.Text;
        private void okButton_Click(object sender, RoutedEventArgs e)
            DialogResult = true;
To display the dialog box from an AutoCAD command, you have to use the Application.ShowModalWindow() method.
using Autodesk.AutoCAD.ApplicationServices.Core;
using Autodesk.AutoCAD.Runtime;
    public class Commands
        [CommandMethod("TEST")]
        public static void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var dialog = new ModalDialog();
            var result = Application.ShowModalWindow(dialog);
            if (result.Value)
                Application.ShowAlertDialog("Hello " + dialog.UserName);
Gilles Chanteau
GileCAD
GitHub
Message 3 of 16
_gile
To add a WPF modeless dialog (typically a PaletteSet) to your AutoCAD plugin project, you have to add a "User Control (WPF)" to the project.
XAML:
<UserControl x:Class="SimpleWpfPalette.PaletteUserControl"
             xmlns:local="clr-namespace:SimpleWpfPalette"
             mc:Ignorable="d"
             d:DesignHeight="450" d:DesignWidth="800">
    </Grid>
</UserControl>
in the code behind, you can call a custom AutoCAD command with sendStringToExecute to avoid ahaving to lock the current document and set the focus to AutoCAD application:
using System.Windows.Controls;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace SimpleWpfPalette
    public partial class PaletteUserControl : UserControl
        public PaletteUserControl()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            if (doc != null)
                doc.SendStringToExecute("HELLO " + nameBox.Text + "\n", false, false, false);
You add to your project a class for your custom palette set which derives from PaletteSet in which you add the Usercontrol using the AddVisual() method.
using System;
using Autodesk.AutoCAD.Windows;
    public class CustomPalette : PaletteSet
        public CustomPalette()
            : base("WPF Palette", "SHOW_PALETTE", new Guid("{1E20F389-33C1-421F-81CB-B3D413E5B05C}"))
            Style = PaletteSetStyles.ShowAutoHideButton |
                    PaletteSetStyles.ShowCloseButton |
                    PaletteSetStyles.ShowPropertiesMenu;
            MinimumSize = new System.Drawing.Size(250, 150);
            AddVisual("Hello", new PaletteUserControl());
From an AutoCAD command you show the palette (and create it if it not already exists). this class also contains the command called from the button in the palette.
using Autodesk.AutoCAD.EditorInput;
        static CustomPalette palette;
        [CommandMethod("SHOW_PALETTE")]
        public static void ShowPalette()
            if (palette == null)
                palette = new CustomPalette();
            palette.Visible = true;
        [CommandMethod("Hello")]
        public static void Hello()
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var pr = ed.GetString("\nEnter your name: ");
            if (pr.Status == PromptStatus.OK)
                Application.ShowAlertDialog("Hello " + pr.StringResult);
Gilles Chanteau
GileCAD
GitHub
Message 4 of 16
Exactly what I was looking for!  Thank you very much.
Message 5 of 16
essam-salah
HI @_gile
 mc:Ignorable="d" Height="100" Width="50">
the window has a fixed height and width, even with the new value (100,50)
any help
Message 6 of 16
_gile
@essam-salah  a écrit :
HI @_gile
any help
Sorry, I do not understand your question.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 16
essam-salah
I want the window to be smaller
Message 8 of 16
_gile
Still not sure to understand, but try:
Height="100" Width="50" ResizeMode="NoResize">
Gilles Chanteau
GileCAD
GitHub
Message 9 of 16
essam-salah
sir @_gile
i have a problem but its related to c# more than .NET if u can help.
i wanna link a wpf control  event(combobox1_selectionchanged) to main code in the transaction
        private void Combobox1_SelectionChanged(object sender, SelectionChangedEventArgs e)
            //textblock1.Text  = somthingFromTransAction; // ????
Message 10 of 16
_gile
@essam-salah, Please start a new thread to ask your question because it is different from the OP.
And try to be more clear and detailed in your request if you want someone to be able to reply you.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 16
BKSpurgeon
Hi Gilles
Thank you for your answer. Not just this answer, but all the answers on the forum.
Re: the above code, when the ok button is clicked, the Dialog Result is set to true. Was wondering if you knew a MVVM way to handle this?
  • When the button is clicked a command should fire; and when this command runs, it should somehow close the window. In this case, the ViewModel should not know anything about the view. Is there a way to handle this?
 public class OverWritePanelsViewModel
        public OverWritePanelsViewModel()
        private ICommand _endCommand;
        public ICommand EndCommand
            get
                if (_endCommand == null)
                    _endCommand = new RelayCommand(
                        p => { // what should go here to close the window? },
                        p => { return true; }
                return _endCommand;
/// And here is my XAML:
<Window x:Class="BKTools.GrabCopy.OverWrite"
             xmlns:local="clr-namespace:BKTools.Tools.GrabCopy"
             mc:Ignorable="d"
    <Grid>
        <StackPanel >
            <Button Command="{Binding EndCommand}"> Ok</Button>
        </StackPanel>
    </Grid>
</Window>
Message 12 of 16
_gile
@BKSpurgeon
Even implementing MVVM, you can use the code behind for a modal dialog box OK button which only set the DialogResult to true.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 16
norman.yuan
You can bind the Window itself to the command as CommandParameter in the XAML, like this
<Window x:Name="MyDialog" x:Class=... ...>
  <Grid>
      <Button Content="OK" Width=100 Height=20
                     CommandParameter="{Binding ElementName=MyDialog}" />
  </Grid>
</Window>
Then in the ViewModel, you have the command like this:
_endCommand=new relayCommand(
     p => {
                 var win=(System.Windows.Window)p;
                 // You can either set the window's DialogResult value
                 win.DialogResult=true/false;
                 // Or you can expose a ViewModel's public property to desired value
                 // if the ViewModel remains for next step to get data manipulated by the UI after the view is closed,
                 // this property would indicate if the view is cancelled or not.
                 // then you can close/hide the view, regardless the DialogResult value
                 this.DataOked =  true;
                 win.Close()/Hide();
     p => { return true; });
The point is that the command parameter is bound to the view Window object, so it can close it.
Norman Yuan
Drive CAD With Code
Message 14 of 16
_gile
If you absolutely want to handle the DialogResult from the ViewModel, you can set the CommandParameter of the button to the Window and use this paramater in the EndCommand
XAML
        CommandParameter="{Binding RelativeSource={RelativeSource Mode=FindAncestor, AncestorType={x:Type Window}}}">Ok</Button>
ViewModel
public RelayCommand EndCommand =>
    new RelayCommand((dlg) => { ((OverWrite)dlg).DialogResult = true; }, (_) => true);
One more time @norman.yuan was faster 😉
Gilles Chanteau
GileCAD
GitHub
Message 15 of 16
_gile
Another way could be implementing a Button.IsAccept DependencyProperty (similar to Button.IsCancel) as shown in the first reply of this topic.
Gilles Chanteau
GileCAD
GitHub
Message 16 of 16
BKSpurgeon
Thank you very much @norman.yuan and @_gile
