I just fix and tested full code, for any need to use in future :
using System.Collections.Generic;
using System.Windows.Forms;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using Application = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Test;
public class TestViewPort
[CommandMethod("TestInsideViewport")]
public void TestInsideViewport()
Document doc = null;
Database db = null;
Editor ed = null;
try
doc = Application.DocumentManager.MdiActiveDocument;
db = doc.Database;
ed = doc.Editor;
LayoutManager layoutManager = LayoutManager.Current;
string layoutName = layoutManager.CurrentLayout;
ed.WriteMessage($"\nLayout Name: {layoutName}");
ObjectId layoutId = layoutManager.GetLayoutId(layoutName);
ObjectId vpId = ObjectId.Null;
using (Transaction tr = db.TransactionManager.StartTransaction())
Layout layout = (Layout)tr.GetObject(layoutId, OpenMode.ForRead);
var vpIds = layout.GetViewports();
if (vpIds.Count > 1)
vpId = vpIds[1]; // First Viewport is Paperspace itself
tr.Commit();
if (vpId.IsNull)
throw new Exception(ErrorStatus.Vetoed, "viewport have issue");
List<Point3d> vpOutlinePntsInMs = null;
Viewport vp = (Viewport)tr.GetObject(vpId, OpenMode.ForRead);
Polyline vpOutlineInMs = null;
if (vp.NonRectClipOn)
ObjectId vpClipId = vp.NonRectClipEntityId;
Entity vpBoundary = (Entity)tr.GetObject(vpClipId, OpenMode.ForRead);
vpOutlineInMs = (Polyline)vpBoundary.Clone();
else
Extents3d vpExt = vp.GeometricExtents;
vpOutlineInMs = new Polyline(4);
vpOutlineInMs.AddVertexAt(0, new Point2d(vpExt.MinPoint.X, vpExt.MinPoint.Y), 0, 0, 0);
vpOutlineInMs.AddVertexAt(1, new Point2d(vpExt.MaxPoint.X, vpExt.MinPoint.Y), 0, 0, 0);
vpOutlineInMs.AddVertexAt(2, new Point2d(vpExt.MaxPoint.X, vpExt.MaxPoint.Y), 0, 0, 0);
vpOutlineInMs.AddVertexAt(3, new Point2d(vpExt.MinPoint.X, vpExt.MaxPoint.Y), 0, 0, 0);
vpOutlineInMs.Closed = true;
Point3d center = new Point3d(vp.ViewCenter.X, vp.ViewCenter.Y, 0.0);
Matrix3d msToPs =
Matrix3d.Displacement(new Vector3d(vp.CenterPoint.X - center.X, vp.CenterPoint.Y - center.Y, 0.0)) *
Matrix3d.Scaling(vp.CustomScale, center) *
Matrix3d.Rotation(vp.TwistAngle, Vector3d.ZAxis, Point3d.Origin) *
Matrix3d.WorldToPlane(new Plane(vp.ViewTarget, vp.ViewDirection));
vpOutlineInMs.TransformBy(msToPs.Inverse());
vpOutlinePntsInMs = new List<Point3d>();
for (int i = 0; i < vpOutlineInMs.NumberOfVertices; i++)
vpOutlinePntsInMs.Add(vpOutlineInMs.GetPoint3dAt(i));
// Draw polyline in model space
Polyline transformedPoly = new Polyline();
for (int i = 0; i < vpOutlinePntsInMs.Count; i++)
transformedPoly.AddVertexAt(i, new Point2d(vpOutlinePntsInMs[i].X, vpOutlinePntsInMs[i].Y), 0, 0,
0);
transformedPoly.Closed = true;
transformedPoly.ColorIndex = 1; // Red
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord ms =
(BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
ms.AppendEntity(transformedPoly);
tr.AddNewlyCreatedDBObject(transformedPoly, true);
tr.Commit();
BlockTableRecord blockTableRecord = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db),
OpenMode.ForRead);
foreach (ObjectId entId in blockTableRecord)
Entity ent = (Entity)tr.GetObject(entId, OpenMode.ForRead);
if (ent is Polyline)
continue;
var pt1 = ent.GeometricExtents.MinPoint;
var pt2 = new Point3d(ent.GeometricExtents.MaxPoint.X, ent.GeometricExtents.MinPoint.Y, 0);
var pt3 = ent.GeometricExtents.MaxPoint;
var pt4 = new Point3d(ent.GeometricExtents.MinPoint.X, ent.GeometricExtents.MaxPoint.Y, 0);
if (IsInside2D(vpOutlinePntsInMs.ToArray(), pt1) &&
IsInside2D(vpOutlinePntsInMs.ToArray(), pt2) &&
IsInside2D(vpOutlinePntsInMs.ToArray(), pt3) &&
IsInside2D(vpOutlinePntsInMs.ToArray(), pt4))
if (ent is BlockReference block)
ed.WriteMessage($"\nEntity Block in Viewport: {entId.Handle} ({block.Name})");
tr.Commit();
catch (Exception ex)
if (ed != null)
ed.WriteMessage("\n Error: " + ex.ToString());
else
MessageBox.Show("Error: " + ex.Message, "TestInsideViewport", MessageBoxButtons.OK,
MessageBoxIcon.Error);
private static bool IsInside2D(Point3d[] polyPoints, Point3d entPoint)
bool oddNodes = false;
int i, j = polyPoints.Length - 1;
for (i = 0; i < polyPoints.Length; i++)
Point3d pp_i = polyPoints[i];
Point3d pp_j = polyPoints[j];
if ((pp_i.Y < entPoint.Y && pp_j.Y >= entPoint.Y || pp_j.Y < entPoint.Y && pp_i.Y >= entPoint.Y) &&
(pp_i.X <= entPoint.X || pp_j.X <= entPoint.X))
oddNodes ^= (pp_i.X + (entPoint.Y - pp_i.Y) / (pp_j.Y - pp_i.Y) * (pp_j.X - pp_i.X) < entPoint.X);
j = i;
return oddNodes;
Chuong Ho
