View Table
View Table
View Table
Good Morning,
I have a simple program that when run checks if a given view is in the View Table for a drawing, if it is it will load it by default. The program works fine when it checks for the view. However the problem I am running into is that it does not change to the view afterwards. Any thoughts? Code below.
<code>
[CommandMethod("def")]
static public void DefViewLoad() // This method can have any name
//Set current application session
AcadApplication app;
app = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
// Get current DWG Database
Document acDoc = Application.DocumentManager.MdiActiveDocument;
Database acDB = acDoc.Database;
//Set Editor to save typing
Editor ed = acDoc.Editor;
//Start Transaction to play with DWG.
using (Transaction acTran = acDB.TransactionManager.StartTransaction())
//Open current drawing layer table listing and read.
ViewTable acVT;
acVT = acTran.GetObject(acDB.ViewTableId, OpenMode.ForRead) as ViewTable;
ViewTableRecord acVTRec = new ViewTableRecord();
if (acVT.Has("test")==true)
ed.WriteMessage("test works");
acVTRec.Name = "test";
ed.SetCurrentView(acVTRec);
acTran.Commit();
ed.Regen();
</code>
chiefbraincloud
You have simply created a new ViewTableRecord (with defaults which would match the currently active settings), then named it "test" and set the view.  You need to open the existing record to pass to SetCurrentView.
I use VB, so I'm not going to try too hard to get this syntax right, but you should get the idea.
if (acVT.Has("test")==true)  // This can return true for erased objects
acVTRec = acTran.GetObject(acVT("test"), OpenMode.ForRead, False); //Open the record
  // I would check here to make sure acVtRec.IsErased = False
  if (acVTRec.IsErased==false)
